Due to a lack of space, we decided to go with n-scale and followed the N-17 layout plans we found in a magazine, I forget what the name was. (this is our first layout)
This plan calls for 9 and 3/4 inch radius curves on an inside main line…my passenger cars do not seem to like this radius.
The layout was stretched to 84 inches by 36 inches…I am considering making it 90x42.
The larger curves are 11" radius, and the passenger cars look a bit strained on those too.
Using flex track, by Atlas, code 80, would a 12 inch and 13 and 1/2 inch radius be acceptable?
I soldered all the track together and some one has said there should be gaps cut in the nickel-silver rails because they will expand and kink when the weather warms up…is this true, and since the track is already together, how would I go about this, and how big a gap is needed?
All of the freight cars run fine through all curves, all the engines run fine through them, RS-2s and GP9s…no problems at all with turnouts and electrical work…just long cars around the curves…no room to expand these curves on this layout, which is why we are considering making it a bit longer and wider.
