Have a couple of basic questions, anyone have some thoughts or ideas?
1. TMCC “Whatchdog Signal” and power up timing.
- Basic premise is that the TMCC Command Module has to be powered up BEFORE power is applied to the track.
To date I have had the power to the layout as follows; From wall to a “Master Switch”, (fuse protected), then to a Surge protector which has the TMCC Command plugged into that. Another, surge protector is plugged into the first one, and the ZW bricks are plugged into it. (Possibly a micro second delay?) The TIU is plugged into the first surge protector. This has been working fine. However, recently (past 2 months or so), if I “start” a TMCC engine it may not have received the watchdog signal. Andstarts in conventional mode. Now, IF I start a DCS engine first, the TMCC engines start in Command mode !
Solutions I am thinking about is either put a “2nd” master switch one dedicated to the TMCC Comand Base, OR leaving the Command Base on 24/7. Which i don’t really like. Do any of you leave the Command on all the time??
2. Caboose marker lights. I have had a perpetual problem with the marker lights on cabooses. As fast as I can replace the LED’s, I will have one go out. I have the track power at 18v. The best I can put together is that a surge from a derailment or a car shorting may be causing the problem. Only thing I can think of is either a diode or resistor in the caboose. Or, reduce the voltage.
3. Drastic drop in Sound. Does anyone have any idea why the sound on a TMCC engine will go suddenly to a near mute state? And, what do you have to do to recover it? Cant seem to get it back to regular volume. Checked Eng Snd button, Volume Button, replaced battery in engine, restored default settings. Still get volume as being barely audible. Hmmmmmm
Appreciate any thoughts!<
