Go to a hobby store and measure the ‘G’ scale stuff (LGB for one brand)
You’ll find that you need 10" to 12" clearance.(Including; support, shelf, track, & train)
Waht size is your basement ceiling?
Bringing a ‘G’ train down 15" to 18" might overwhelm the room.
Given what you said already I would go with ‘O’ gauge/scale.
G trains kind of range in size from a scale proportion of 1:32 all the way up through 1:20 or so. The trains are about 8" tall. There is only one gauge of track for all of those different sizes of trains. The G experts can be found on the Garden Railways forum here at Trains.com. It sounds like you have a pretty good vision of what you want the layout to look like, I think she’ll like it. [swg]
Yes, the TMCC is great for the shelf layout. If your trains have cruise control (Kline) or the Oddyssey speed control (lionel) you can as the info-mercial says: set it - and forget it! I also used the momentum setting on the CAB-1 controller. This regulates the maximum speed your train can go which helps if you have kids using the trains at all.
Quite honestly, I am still not 100% comfortable yet with the trains going overhead. Derailments have alwya sbeen part of my trains, and if I get one, its a long way to the ground. No Speeding!
well garden trains are out . so “O” is the way I’m going. so back to needing help. what are the bridge sizes ( covered, designer, open, ect…)are there tunnels that go against a wall? ?? corners on shelf system,(flex ,.027 setw/ base?)can i us a cable 1/2 the hight of train as protaction if there’s a derailment?
“O” pricing --best which names are the best in --tracks, loco’s trainsformers,ect…
i have stopped at two stores & i’m get not alot of help (just what they want to sell.)
trust facter LOW.
The key word is how do you define “BEST”. And how “BIG” your budget is going to be for this project. Since it is going to above eye-level it doesn’t seem to make a lot of sense to use the the real hi-end track unless it would be beneficial for operating purposes. From my very limited experience I would suggest going with TMCC since it is being used by a greater number of manufacturers. [2c]
hi, grumpy — "BEST = most for the money that well last the longest. this is to start a rec-room type deal we’ll see once I get into it. track 1st , corners that fit , transformer that’s the right size, wireing that keeps it ok --running all (most ) of the time,bridges,tunnels,& then the train set.
It sounds like one basic decision has been made, that’s a good start. O gauge it is then.
Let’s plan the track, then the rest will fall into place.
Single loop of track?
Single train?
No switches?
If the answers are yes, then I’m thinking Williams engine, to keep it simple, forget TMCC. For this project I like Atlas track, since the solid rail will make less noise. Any simple transformer, such as an old 1033.
My suggestion to you would be to get a current catalog from Lionel, MTH, & K-line.
Then buy the latest issue of CTT & OGR.
Also a beginner’s book like OGR’s ‘The Primer’ will be helpful.
Armed with this info. look through the adds of both mags and find a good price on a starter set. (Set does not have to have track and trans, since you’ll be adding more track and will probaly out grow the stanard trans.
Next is to plan an attack. What is your buget? What is your track plan?
How, Where, and from What will you hang the track?
What materials will you use?
The mags can provide pre-enginered ceiling mounts or you can turn to this forum and search and/or ask for detailed do-it-your self system.
Once you have a plan add up your linear feet and buy your track.
I prefer Gargraves Trackage. It has been around for years, It is cost effective, Looks great, Has real wood ties, and is meant to be bent into any curve you want. This eliminates the need to buy extra curves.
Some of the things you’ll need most are a good plan and the resolve to see it through.
Happy Railroading! & remember we are here to help (well most of us) [:)]
Since it will be on the walls close to the ceiling I would suggest going with O scale. I have both the scale and non-scale on mine and it doesn’t seem like much of a difference on paper but when you are looking up at the locos and rolling stock it seems to make a big visual difference. [:-^]
Before spending too much money on books, I suggest checking to see what your library has. There’s enough interest in Lionel trains that larger libraries often have some titles.
Check out any book by Peter H. Riddle you can find. You’ll probably end up buying several of them, but they’re worth reading first. His wiring books and his tips and tricks book will give you tons of insight. I dare say after reading them, you may not need any help from the people at the hobby shop.
As far as service at hobby shops, sometimes the people aren’t helpful just because they don’t know. I’ve got three good hobby shops close to me. One is trains only, and the service there is exceptional. The other two are general shops that sell everything. Both of them have one person on staff who really, really know trains. Next time you visit either of your local shops, if the person doesn’t seem to know much, ask if there’s anyone who works there who has a Lionel layout at home. If there is, they’ll probably tell you the person’s name and the hours he or she works, especially if you say you’re looking to buy quite a bit of stuff.
We were putting in a family room (18x18) and wanted to incorporate the trains (O gauge) is some way. I was able to build a 6" shelf around 3 of the walls and a 20" deep bookcase on the 4th wall. This allows for 3 or 4 tracks across the top of the bookshelf. There were 2 tricky parts. The first was a staircase coming into the room. We cut a hole through the side of a riser along the wall and it made a great tunnel entrance. Where we crossed a doorway a fold down shelf/bridge was built that alligns the track perfectly every time. All my wiring and power was able to be hidden from sight inside the bookshelf.
I used Gargraves track and Ross switches. By using TMCC I have no power packs or controllers out in the open. I used a 6" triangle shaped piece of wood at every stud to support the shelf. I found these pre-cut at Home Depot.
On the walls I used shelving from Glenn Snyder display systems out of Buffalo. It’s aluminum and strong. I put 12’ of trains on each shelf and it holds them easily. It is not very expensive either.
By doing it this way we were able to have our family room and trains all in the same place. It turned out great and looks pretty good too. If anyone is interested in a pictures I’d be happy to temail them to you.
tschmidt-- please e-mail pics. the lie-outs are very close to each others. thanks for info and in advance for the pics. —tbeakey@rspeedinc.com— thats my son’s (he gets e-mail pics. that i don’t get.) —jbeaks2@aol.com— is my e-mail.
