Newbie - Power ?s
Hello:
This Spring, we are considering venturing outside and thinking about a Garden Railroad. The anticipated run will be small, about 200 feet to start.
Questions:
What transformer should we consider?
On our indoor Lionel layouts, the power to the tracks gets a boost about every 10 feet or so. Will the garden track run have to be boosted also and about how many feet between the power connections?
Lastly, your suggestion for the best basic (simple for this “older” guy to understand) publication on the "nuts and “bolts” of Garden Railroading.
As always, many thanks.
Well to start with I would have to say 200’ isn’t small, sounds like a pretty good start to me. I used mostly MRC transformers, which was what was popular several years ago and I’m sure others on the forum can offer more current suggestions. Of course it depends on amperage of needed by the engines. I currently use a home built one with a 15 amp/24vdc output controlled by a 2 LGB 52121 remote controller protected by 15 amp circuit breakers. The hi voltage transformer is kept inside and the low voltage remote controllers receive power via 14 gauge wire, remember electricity doesn’t get along well with water. Each block is supplied with connections at about every 15 feet. I have found this to work pretty good, the biggest problem coming from the rail joints, the fewer the better ( longer track pieces ) securing with clamp on joiners and using a dielectric grease available at hardware and big box stores, you can also solder jumper wires at the joints and this seems to work the best. Enjoy your new hobby it is a lot of fun and give you years of enjoyment. Good luck, Bill Coquina Falls
I started with a Piko 4 foot circle starter set back in 2013 and now have 456 ft double main line with a 6 track 40 ft yard, I use a couple Bridgwerk’s controllers and 20 amp power supplies, all my rail joiners are brass and two jumper cables in the middle of the RR. Lots of fun with my 7 year old daughter, here a link to my RR https://www.youtube.com/watch?v=NQDNctN0NbE and a new link with my daughter https://www.youtube.com/watch?v=G60N9RUkZ-E Jose Silva
When I started off into MR (1999) I accessed and acquired quite a few hard copy references. Also utilized Geroge S. website;
http://web.archive.org/web/20140810061542/http://www.girr.org/girr/tips/tips.html for quite a bit of insight into our hobby !
BTW, I acquired a MRC G transformer, in case the PHHobby Gpower did die off a few yrs back when the meter died, but it still pushing out over 22v max.
I’ve heard of peoples acquiring the Bridgewerks power units. I mihgt have but they were not available locally at the time.
good luck,
doug c
My advice to new to the garden, ALWAYS buy bigger. As a self admitted “analog dinosaur” I’ve been pushimg electrons down the rails since 1995. My empire has grown in pre-planned stages, and one not planned when “She Who Must Be Obeyed” said “I want to send a train off into the distance and it not come back for a while.” That one ran along the back fence weaving through her roses (180 ft) and turned to weave amoung her fruit trees.
Transformer: Learn from my fail. As time went along each exoansion created a need for more power. My storage shed holds 5 working transformers that were not big enough to handle the expansions. Guesstimate your power requirements five years from now, find a transformer to fill that need, then buy the model two sizes bigger. You will save money in the long run.
Switches (Turnouts): Buy more than you need for you beginning plans. Position them as ‘stub end sidings’ that can become expansion points for later construction. In my case initial construction was a basic oval around the Koi pond. Switches were installed for future track yard, future bridge to the Chateau atop the waterfall, etc. When installing switches remove the ‘slip joint’ rail joiners and repalce with rail clamps. Domestic and nondomestic wildlife have a tendancy to leave “gifts” on the switches, and dirt and small rocks also collect there. Rail clamps allow you to lift out the switch without disturbing any of the rails so you can easily take the switch to a work bench for complete cleaning, or repairs if needed.
Rail joints: As the ground shifts under our empires the standard slip joint connectors will become mis-aligned giving the oportunity for derailment. Use short setional track where you must, but longer ‘flex’ rails when ever possible. For my longer runs I soldered two 10 foot sections together for 20 ft pieces and joined them with rail clamps to the next section. The fewer joints you have makes for less oportunity fo
ChoCho Willy: Doug C: Tom Trigg:
Thanks, so much, for your replies. We are looking foward to the adventure. As things develope, we will post updates. Have a great holiday and thanks, again.
The biggest factors are the rail material and the joiners used. Different recommendations for aluminum vs. brass vs. stainless steel rail.
Might I suggest you read this page, and the 10 pages linked at the bottom.
This will get you a start!
Greg
As a newbie myself, I echo the advice given on this page. These folks gave me much the same when the Triple O went from idea to railroad a couple years ago. It paid off in terms of where to place limited dollars as well as mistakes avoided!
I might add one observation of my own, and that is on the control side of the transformer. Consider the the demographic of the crew. I was about to throw down for DCC, but that would’ve added capability beyond the very young crew’s ability to operate and, due to its cost and relative complexity, this would’ve detratcted from my ability to enjoy them operating the trains relatively stress free!
As Tom said, start digging. No regrets from this clan in the Aloha State beyond we wish we had broken ground earlier!
Eric
Greg…Eric…THANK YOU.
To all:
It’s been a little too cold to venture outside but the “dream” still exits.
Thanks, again, for your posts.
I would recommend Kevin Strong’s book Garden Railway Basics as a place to start your journey.
There is also the Mark Found 15 part British video series The Garden Railway. It’s pretty basic and glosses over quite a few of the details but you might find it entertaining and informative.
I’m late replying to this post but have you considered battery power versus growing multiple transformers each time you expand? I switched some years ago and havn’t regretted the move. I don’t have to polish track and I can add or change track on a whim. Growth of track is not a problem nor is a change of rail material and I can do reversing loops without a ton of circuitry. The down side is that it costs about $200 for a decoder and battery for each new engine I convert.
I will also chime in and second the motion that you investigate onboard battery RC with either Revolution or Airewire control system, or even the new bluetooth control to allow your smart phone to control the train(it is harder to see outdoors depending if your in bright sunlight or under shade trees however). I went with onboard battery power after close to 10 years running track power, I grew tired of dealing with rail joiner issues, having to clean track and I was diving into live steam engines, of which most do not play well with track powered trains. I have never looked back. My indoor loop can have track power, I keep that option for testing new models and fixing ones for others. I am picky on what locomotives I puchase as I dislike having the batteries in a trailing car unless its the steam locomotive’s own tender. I have engines from LGB, Kalamazoo and Lionel Large Scale(the older line, not the new all plastic crap) that have onboard battery power installed in them. Mike the Aspie
