I am essentially new to model trains (my family had a 4x8 HO scale when I was a kid – I am 39 now). I have two young boys (3 and 5) and I decided to get them (and myself, I’ll be honest) a train set. I have an MTH O-scale starter set coming, along with some extra RealTrax. I have been building a 4x7 table and playing with layout ideas while I wait for the set to arrive – I haven’t been this excited about Christmas in a long time.
Anyway, the set comes with a Z1000 transformer. Is there any kind of built-in speed governor? I will be setting up a continuous loop track (sort of a doubled-over figure 8 with some short sidings) and would like the boys to be able to work the transformer without risk of sending the train off onto the brick floor. I want to keep the speed down.
Since the Z1000 appears to have a knob throttle, I suppose the keep-it-simple solution would be to loop a wire or string around the handle and fasten the other end at an appropriate spot on the table so that the knob can rotated only so far.
Assuming no built-in governor on the transformer, what other techniques can be used? Thank you for any advice.
The set you are getting should have a fairly heavy engine that will stay on the track well, as well as speed control. Speed control, when enabled, will allow the engine to maintain a constant speed through curves, and up and down grades, without any throttle attention. As a result of this, the engine must always keep several volts “in reserve”, and thus shouldn’t move fast enough to come off the track even at full throttle.
OK, I’ll wait until the set arrives and see how well the speed control feature works. If it doesn’t do the trick, then I’ll look at some other techniques.
From experience (my own as a boy and much more recently with a “new to trains” 11 year old running my old Lionel trains), you won’t need to worry too much about a “speed governor” or other speed control for your new trains. O tinplate - Lionel, MTH, etc. - because of the tubular track, greater weight and deep flanges can tolerate an amazing amount of speed before leaving the track. One word of caution though - this is only true if the track is carefully put together! The 0-27 tracks I assembled for the 11 year old didn’t see derailments, even when he turned up the old Lionel transformer to its maximum - but the tracks he attempted to assemble temporarily (and did so sloppily), did see a derailment. Fortunately this last was with tracks on the floor, so no damage beyond his surprise. Interestingly, he didn’t try that again.
One other hint - if you do find the need for a top speed reduction technique, my suggestion would be to avoid pieces of string or ‘prone to overheat’ resistors, and simply buy a few lighted accessories or cars. I don’t knowt he Z1000 directly, but the transformer packed with most starter sets is fairly small, and a few lighted accessories should draw enough current from the transformer to reduce it’s top voltage by a useful amount - the higher the load on the transformer, the lower the output voltage.
Jkeaton, thanks for that info. I am glad to hear that the O-scale track is fairly speed tolerant.
The lighted accessories or cars idea is a great hint, although I am amazed at how expensive such things are.
Forget speed control for a second. If I just wanted to hook up a plain light inside a plastic house, for example, is there a recommended light fixture/bulb combination for that purpose? I guess what I am asking is: what kind of light is inside the pre-made lighted accessories and cars? Are they readily available at hardware stores?
