I’ve been posting this in the General forum under another thread when I should’ve really made a new thread here, so here it is.
Originally I wanted to model H0 as I already have some equipment, but if push comes to shove, I would switch to N.
To give you an idea what the space really looks like, here are two photos, looking East and looking West. It’s fully finished, as a living space not a train room.
Below is what my basement area for trains looks like, and its dimensions. The ceiling height is pretty low, 6’5" the most.
I need to keep the access to the electrical cabinet in the upper right, and then below the support pillars is the hallway that I can’t block either, or the door to the room on the left.
I did think of a number of shapes to fit in the space, but as a n00b I am not too sure whether these shapes are the best I can do/get. Dots are for the duck-under or swing-gate bridge.
These aisle spaces are pretty tight, probably 2-2,5’
I’m also thinking about around the perimeter incline/decline to the second level, instead of a helix (the space hog).
S is the staging and trains could arrive into it from either 1 or 2. As long as there’s access to the panel then 2 can remain lowered.
I do not have a prototype railroad I’m modelling, nor I wish to really base myself on one, as I do not have a preference. I’d rather select from various ones features I like and incorporate into my model.
What I’m struggling with, beside H0 or N scale, is how does one actually go about planning a room size layout:
do you come up with the layout shape first, and fit the industries and locations into it; or the other way around; or even something else?
how do you know where to put yards, interchanges, stations, industries, etc. in your layout shape?
what method one uses to determine whether all these features (industries, yards, stations) work together in a meaningful operational manner?
how do you create interest (switching puzzles, etc) in specific locations such as yards, interchanges and industries?
I believe it is 3’ from the front face of the panel board, and that space is basically what is needed to open the door enclosing the electrical closet space anyway.
Looking at the third and fourth images where the benchwork appears to be fairly deep.
Can you sketch in a line, approximately parallel to the front edge of the benchwork, that represents your personal reach-in limits? 24" is comfortable, 30" starts getting a little far, more than that creates concerns.
It isn’t just reach-in-and-grab something. You need to be able to reach in and remain steady while you perform fairly delicate hand maneuvers to re-couple stubborn cars or clear tiny bits of unwanted debris. Switch throws may or may not be a problem. There are electro-mechanical devices to help; even piano wire gizmos to extend to the fascia.
There was an article a while back (I believe in RMH) that did an extensive analysis comparing the space efficiency of the different shapes. In case you don’t want to go searching for it, the punchline is that the G shape is the best choice.
The one thing I would suggest you change in your sketches is that since you need both access to the electrical panel and access to the center of the layout, make the sacrifice do double duty by flipping your first sketch so the entrance to the center is at the electrical panel.
I’m not much use regarding trackplans or even layout benchwork arrangements, but my suggestion would be to make that area a separate room, with walls between the posts and a wall with an outward-opening door on the angled area. This will make layout maintenance (cleaning - track and other stuff) a lot easier and less frequent.
I also think that the space would be more useful in N scale, as an HO layout as ambitious as your drawings suggest would have greatly compromised radii if you want a reasonable aisle width.
Carl’s suggestion regarding layout and electrical panel access is a good one, too.
A good place to start is determining your minimum radius curves, then placing 90/180/etc. degree curves around the layout space to try out different arrangements.
Answers to many of your questions can be found in publications on “planning for realistic operations” offered by MR. These are especially valuable in avoiding rookie mistakes and helping you decide your priorities.
There are a number of ways to approach layout design. There are a couple of good examples in Track Planning for Realistic Operation. In the 3rd Edition, Chapter 9 describes Armstrong’s method pretty well. Appendix A is another case study of the process.
Personally, I like to do a fairly unstructured Conceptual Phase first, followed by a Structural/Footprint Phase, and only then moving to Details. This is briefly described in the notes page to the four-hour Layout Design Bootcamp I have presented at NMRA national conventions in conjucntion with the Layout Design SIG. Notes page found here: http://www.layoutvision.com/clinics.html
I would suggest that you might want to step back to the Conceptual Phase. Think about what kinds of trains you’d like to see and what you’d like to do (yard switching, mainline running/model railfanning, etc., etc.). Many newcomers find that they’re not really sure what they want to achieve in their model railroad, so visiting other layouts is a really helpful thing. (As is a smaller “chainsaw” layout where you can try things out, as I suggested to you elsewhere. You can start small, figure out what you like, and then design the next larger layout with those things in mind.)
Basically, you’re coming up with a stretch of railroad that you’d like to model – either prototype (a real railroad) or freelance (from your imagination).
From this, you’ll be able to have a rough idea of the types of trains and equipment, era, locale, train length, etc., etc. As I think I posted in another of your threads, this “lineal” of train length helps me decide how long yard(s), passing sidings, staging, etc. should
I updated all of my sketeches with 1’ grid so it’s easier to see the relationships. Although my shape sketches are not that precise, they are just an idea to go off of.
I’m not sure enclosing this space in the room would work for me, it is already conditioned (heating and cooling) plus if the layout needs to be taken out and space restored back to the original look, no walls makes it easier.
As suggested, I flipped sketch #1 over horizontally, but this configuration does not appear to give my choice for any kind of a yard or such.
thanks for the crash course in layout planning thinking. We (my SO and I, the primary operators of our railroad) did sort of go through those phases but keep turning back to the fundamental question of H0 vs N, besides those you mention.
We did visit couple of bigger layouts to see what’s possible in similar (to bigger space). One was a LHS display (H0) and the other semi-club layout (N) connected to another LHS.
In your second drawing the doughnut shape is what Armstrong described in the Track Planning book on page 88, correct (it is an evolution of the island shape, and he called the access area problematic due to a duck under)?
To me the central access area seems like wasted space, especially on the size of the space we have here, or do you suggest we build a chainsaw layout like this first?
Overal, N scale seems to be getting more appealing now considering that our space could use additional 3-4 feet on the short side to get that additional aisle space for H0. Althoigh, we are not concerned with 30" aisles as we would most likely be the primary users, and are both slim to fit 24".
Sharing more of the priorities that you and your partner have already decided upon may help others help you.
Yes, it’s similar to the middle-left image on that page. But there is an important adition. Because of the opportunity you have along the “column” side of the room, the benchwork could be quite deep along there – with access from both the inside and the outside of the donut. A double-sided backdrop would separate the scenes.
Access to the center may be via duckunder or some sort of movable gate.
Once you widen the benchwork section that has inside/outside access, there may not be as much excess space in the central aisle as you think. The donut may offer a little more usable space in HO for a yard and similar elements as well. The spiral peninsula usually curves a bit more for the given area, so there may be less space for some of those elements. It’s all trade-offs, there’s no one-size-fits-all answer.
If I were doing a chainsaw for your space, I might do something simple in a corner in a water-wing style. Building an island in the center of the room seems logical, but an island and its aisles take up a lot of floor space and may be hard to work around (if you want to leave the chain
Another vote for the G, in any scale that will fit.
About aisleways - 24" is wide enough for one person to move unimpeded. If people have to pass, or there are controls to operate, 32" is better. Also, that isn’t distance between opposite fascia. That’s distence between convenience shelves, cupholders, card boxes and other protrusions.
How big a yard do you want/need. Even in N, a major hump yard is the impossible dream in anything smaller than a basketball court. OTOH, a small yard serving as a consolidation/distribution point for a few towns (or a branchline terminal) can get away with a few tracks for classification and storage, a yard lead/thoroughfare and a main track, possibly with a passing siding thrown in. In N scale, a foot will give plenty of width and leave room for MOW storage and a yard office. My own subdivision yard is 28 inches from the fascia to the ends of the diagonal body tracks - in HOj, which is twice N in scale in bulk (but most of my freight cars are close to N scale length.) Mine also includes rather elaborate arrangements for handling passenger trains and engine changes, which add to the width. I doubt that any North American rail line sees equivalent traffic outside the commuter zones, so facilities can, and should, be simpler.
If at all possible, arrange stand-up entry to the center of the pastry roll, wherever it’s needed. Having to limbo-dance into the central area will get VERY old in a hurry. (You and your co-operators will, too, but not as quickly.)
This is a time to make haste slowly. Your ‘let’s try things’ layout might end up as a corner and the end and one side of the G peninsula, or it might live on as a test bed until all the new things you want to try have been built into the main layout. My test spiral seems to have acquired immortality - every time I think I can recycle the flex track elsewhere I come up with a new radius/clea
Just a quick post about a big yard, we’d love this one that the LHS has in N scale:
We are actually seriously thinking to go N instead of H0 as it seems a logical direction to give us most out of our space. I actually went out and bought a Dash 8-40C, some cars and flex track to play with so we can get a feel for N and its scale.
I will post more specific replies for cuyama and tomikawaTT shortly - I want to talk to my partner first then formulate it into productive queries.
After a brief break, back on the forums (no break from trains though). In what media might call a “landslide” victory, whereas my vote counted for 1 and my partner’s 1.5, it has been decided that we will go with N scale.
A small concession was gained on my part that if possible, a 2nd (or 3rd level could be built to house a small H0 operation thus keeping some of the equipment while the rest will go for sale).
Now that my bemoaning over scales is over, time to focus on what can be done in my space with the N scale.
For the sake of posterity, I made the idea #6 and #7 as mentioned above. One is a G and the other a “doughnut”. I am not sure I did that one right but I’ll fix it if necessary.
So, my question is where do I go from here, what changes with N and having more rail and scenic real-estate?
I also have no clue about minimum curves needed and will have to get that established as well. And, what kind of a layout shape do I now think of when it comes to N scale, in this space?
One of the benefits of going with N scale is that you can run longer trains. However, to do that you need lots of track. I believe the ‘G’ gives you about 100’ of continuous track (give or take) whereas the donut gives you about 75’ of continuous track assuming two basic ovals. If you run three ovals of track on the donut it would give you about 100’. IMHO ovals would be very boring whereas the ‘G’ has lots happening. Scenes can be spread out much more on the ‘G’ as well, and you don’t have to have a duck under or a lift-out. [2c]
