What is the number on the side of the engine? Are the can motors vertical (i.e. they stick up above the frame) or are the horizontal (i.e. they lie down between the wheels inside the truck)?
The wiring diagram is probably on the Lionel web site but you would need to know the number of the engine. The one printed on the side of the cab can be used to get the actual part number to reference the diagrams.
Your scheme is correct. The gray wire has the ground lug in the above pic, brown goes to the center rail roller, black & red to the motors, blue & white are wired to the switch.
