Just coming into this hobby I’m a little overwhelmed by it all. So much to learn and so little time. At age 61 and retired I have the time, but where to start and which way to go is a bit baffleing. I’ve been tinkering around with an O guage shelf layout in my computer room for a couple of years, mounted so that it runs above the doors. O guage is great but it is pretty expensive compared to HO. I’ve been reading everything I can find because I’m about to add a garage on to the house and I’m having a 12 x24 foot room included with it. Time to start thinking more seriously about an HO scale layout. So, that brings me to the questions:
1- should a beginner, like me, start with a 4x8 foot layout to learn the ‘craft’ ? I have Robert Schleicher’s book " The HO Model Railroading Handbook" v3 that has detailed instructions or a variety of sizes and types of layouts, and the temptation is to build one of the larger 7x9 footers as a first try.
2- I want to go DCC and I defintely want syncronized sound. What brands, for the control system and for locomotives, should I lean toward and why?
3- what are some of the do’s and don’ts, things to definitely do and things to avoid, things that you’ve ran into in the hobby that you wish someone had told you about in the beginning.
I wish I knew more about it in order to ask more intelligent questions, or better yet the RIGHT questions, but like all new people… I don’t. So if you don’t mind thinking over those 3 questions, I’d be much obliged[:)]
welcome to the world’s greatest hobby…if i were you…first i would read anything i can get my hands on in the hobby…kalmbach publications has a vast array of books to get you started…then,design a layout …put everything you want on it on to paper and try to draw it to scale as closely as you can…and make sure you get the radii and the distance between the rails you want down pat…next build the benchwork and the backdrop, then lay all the subroadbed and the track…then wire it…and finally…do the scenery stuff…if you try to build the scenery before you wire the layout you’ll be heading for trouble…Chuck[:D]
Jacon, welcome to the hobby! It’s definitely a load of fun. Let’s see if I can help you with your questions:
True, and O scale also takes up a lot of space. On the other hand, how are your eyes and manual dexterity? If you have vision issues or “fat fingers”, O scale (or three rail O) might be the best route. Alternatively, Bachmann has recently taken the hobby by storm with On30: O scale narrow gauge prototype trains that run on regular HO scale track. It’s a very good compromise, is actually somewhat less expensive than regular HO (if you shop for bargains), and is very popular. Broadway Limited Imports (BLI) and a couple of brass manufacturers are jumping onto the On30 bandwagon with engines.
12x24 is about the same size as my layout (mine’s actually a 12x25 three level, but the basic footprint’s the same). You’ll be able to build a decent layout in any scale in that sort of space!
It can’t hurt to learn the basics, but you don’t necessarily have to spend 2-4 years completing a 4x8, just to tear it down to work on that garage layout. How about building a “timesaver” 2x4 layout instead? You’ll learn tracklaying, wiring, soldering, and scenery basics on a small switching layout that you can actually use, and even incorporate into your larger layout. Model
Thanks Chuck and Ray for the information and advice. It will be heeded, hopefully, and I won’t go of on too many tangents I’ll reget later. I’ve read a couple of articles on On30 and found it interesting, but I wondered how O guage would look running down HO tracks. My initial thought was it wouldn’t look right but having never actually seen it, what the heck do I know… [:)] It certainly is an idea to consider.
“How about building a “timesaver” 2x4 layout instead? You’ll learn tracklaying, wiring, soldering, and scenery basics on a small switching layout that you can actually use, and even incorporate into your larger layout”
I like that idea, I was hesitant to do a 4x8 considering the time and expense.
“I prefer BLI’s products, which are their own steam and diesel models with QSI sound decoders factory-installed. These are probably a beginner’s best way into the world of DCC sound. The engines might look expensive, but when you factor in the costs of assembling a steam kit yourself and installing a comparable Soundtraxx sound system, the BLI engines suddenly become cost-effective. In O scales, Lionel and MTH both have their own sound and control systems”
I have two MTH O scale locos now with Protosound 2.0 and it’s awesome. If I do go HO I’ll certainly look into the BLI inventory. I’m not gifted enough to assemble my own.
“if i were you…first i would read anything i can get my hands on in the hobby…kalmbach publications has a vast array of books to get you started…then,design a layout …put everything you want on it on to paper and try to draw it to scale as closely as you can…and make sure you get the radii and the distance between the rails you want down pat…next build the benchwork and the backdrop, then lay all the subroadbed and the track…then wire it…and finally…do the scenery stuff…if you try to build the scenery before you wire the layout you’ll be heading for trouble…”
just like that…click the "quote " icon and take out what you don’t want by either highlighting it by holding down the left click mouse and right click “cut” or you can just backspace out what you don’t need…be sure that it stays between (quote) and (/quote)…Chuck[:D]
[#welcome] The beauty of this hobby of ours is that is full of tangents. You get bored here then go there be it building kits, making trees/scenery or painting. It’s all here. The Nice thing about this forum, though addictive, is it can be a motivator. I’ve hit pot holes and there is always someone to dig me out. This is a virtual club.
As for your question regarding size of layout. Try this:
Start with a 4x8 but with room and planning to expand. I started out with a 4x8 and with a bit of imagination I was able to expand it to a 11x 25 L shape and there will be expansions yet to come.
What maybe a siding can always be turned into a main line in the future.
Fergie, I know what you mean by forums being coming addictive. I’ve been a long time member of the Nikon Talk Forum on DPreview.com and I know how much time you can spend in forums rather than working on the hobby itself. I’ve been in digital photography for about 4 years now and you can see some of my work here… http://members.cox.net/jarrellconley/
I found that in digital you spend an awful lot of time sitting at the computer in the “digital darkroom” working on pictures. My doctor got onto me for that[:(], but he’s right and I know it. I’m hoping that my interest in model railroading will get me up and working on a layout, get more active and still have time for photography. I think the two of them will go well together because I love shooting still lifes!
Thank you for the idea on the 4x8 and working it into a larger layout. Now if I can just decide whether to go HO, O or On30 without going nuts in the process…[:)]
Jarrell
I’m here at work all day long and usually spend my time here because it breaks the monotony of sitting here and doing nothing…any other time i’ll be home working on my layout…Chuck[:D]
I have two, a FE and a FM2 and am contemplating going digital myself. By that I mean top end as the little canon A-300 I have is cute but for what I really want in resolution is inadequate.
BTW if your interested in idle chit chat come join us in the Coffee Shop, one of the other threads on this forum <
Jarrell,Welcome to the forum…My suggestion is try not to read to many different books or articles as it can lead to confusion.Learn as you build as experience is the best teacher.Start with a small layout to gain experience…
About DCC…Some locomotives are not DCC friendly.Buy those locomotives that are DCC ready or DCC equipped such as Atlas,Kato,the newer Athearns’ and Life Like P2K.Atlas and now Life Like (P2K) makes DCC/Sound equipped locomotives as does Broadway Limited Imports.
About sound.You can buy the plug and play DCC/Sound system from Sound Traxx.(www.soundtraxx.com) Very simple to install…
The most popular brands of DCC is Digitrax or Lentz.Both are good systems.
Brakie, You take every opportunity to shoot down the act of reading and I don’t understand why. I am not trying to pick a fight! However, most of us use reading as our first means of learning for some very good reasons; it’s cheap, we can learn from other’s mistakes, we can learn how things operate and the sequence in which they are done.
Instead of saying “My suggestion is try not to read to many different books or articles as it can lead to confusion”, say; don’t be overwhelmed by the things you read and be selective.
Jarrell, Welcome to a fascinating and multi-faceted hobby!! I would buy two books to help get you started. Number one is “Track planing for Realistic Operation” by John Armstrong. The other would be a book containing a description in full of the construction process for building a 4 X 8, 5 X 9 layout. The second book can take you through all the processes of building a small layout. The first is a detailed book on how real railroads operate and the tracks used to do so. Read this book in small doses as it can overwhelm! However, when it comes time to build a room full o’ railroad, this book will help you “learn the ropes”. Most of all do not become overwhelmed! It’s all a fun and wonderful process!
Depending on your method learning, some find reading the preferred method and others, hands-on would be better. Personaly I prefer hands-on but I am finding reading with photos is a good method
Bottom line everyone learns in different ways. Go with what works for you!!
jacon12,
being a retiree, you at least have time to study and build a layout you like. Most people say start small and work your way up. I guess thats good advice, especially when learning about all the products there are out there. Welcome aboard.
Mark,No fights here my friend…Just because one spends hours reading books it doesn’t give the reader any real experiance…Sure one is going to make mistakes…You going to do that anyway and that is a cold hard fact…
Now, I think we both can agree that you can read 2 different books by 2 different authors and get two different views on how things can be done.Understand?
I seen books that confuse me and I been in the hobby 53 years…I seen a lot of things done the hard way…Experiance by doing is the real teacher and that includes learning by mistakes…[:D]
I advocate learning by doing also! There are also many ways to skin a cat! Reading is the way I like to learn. However, I also like to noodle my way through a project and may never pick-up the instructions if I can get by with it! However, if all else fails, read the destructions. We be buds, Brakie!
Here’s my [2c] Read all the forum postings you can. I’ve been surprised at how many topics that I felt wouldn’t pertain to me, actually do. Don’t be afraid to ask questions, let me horribly paraphrase a great philosopher, “The man who knows what he doesn’t know, is the smarter man” There’s no stupid questions. Learn about the Real railroads to. You’ll find a lot of real neat things to model if you study them. Don’t be afraid to rip stuff up and redo it. Espacially when you start. There’s nothing worse then having a great layout but has poorly laid track in one section that ruins the whole thing. Visit trains shows and hobby shops and ask questions there. i just started working at my local hobby shop and myself and the other workers will give you the best advice we can. most hobby shops are like this. Another good book is “track plans for realistic operation” By the late John Armstrong. It has many great chapters on almost every facit of MRR. The most important advice I can give though is just to have fun while doing it.
Andrew
