just finished a work session on this engine, sheesh the problems.
Sometimes models are made too accurate, the cab roof extends out and on shaper curves touches the tender, shorting out.
Solution, remove front washer on tender truck to lower it replaced with a smaller washer, painted liquid insulation on tender/roof where touching.
unreliable power contact on drawbar, added 2 pin wired connectors between engine/tender.
Rear trailing truck crossbar touching drawbar bolt, shorting…
solution-grinded off metal for clearance and removed washer on drawbar pin, had to add kadee coupler pocket mod to prevent drawbar touching frame.
Front pilot truck real left wheel touching inner piston, shorting
solution- paint piston back insulation paint and outside of wheel, bent span bar to shorten length of it.
Engine still kept shorting out after all these fixes…found left front driver touching inner frame and spring detail when pushed in,
Solution, file frame cover back, and bend spring detail in slightly for clearance.
Already with Soundtraxx decoder and superbright LED with working mars light, NOW it runs smooth…woops, derail, drawbar low…er, return spring on it and bend up…okay, runs fine now.
now it runs fine.
Next step is to install the QSI titan decoder, get the marker lights and number boards working, it will be dandy.
The photo is an early shot before any work done
