From http://www.matweb.com
MatWeb, The Online Materials Database
Nickel silver 65-10, UNS C74500
Subcategory: Copper Alloy; Metal; Nonferrous Metal
Key Words: NS103, ISO CuNi10Zn27, CEN CW401J
Component Wt. %
Cu 63.5 - 68.5
Fe Max 0.25
Mn Max 0.5
Ni 9 - 11
Other Max 0.5
Pb Max 0.1
Zn 25
Material Notes:
Excellent corrosion resistance. Excellent cold workability. Fabricated by blanking, drawing, etching, forming and bending, heading and upsetting, roll threading and knurling, shearing, spinning, squeezing, stamping and swaging.
Applications: rivets, screws, slide fasteners, optical parts, etching stock, hollow ware, nameplates, platers’ bars.
Available as flat products and wire.
Physical Properties Metric English Comments
Density 8.69 g/cc 0.314 lb/in³ at 20°C (68°F)
Mechanical Properties
Tensile Strength, Ultimate 338 - 896 MPa 49000 - 130000 psi
Tensile Strength, Yield 124 - 524 MPa 18000 - 76000 psi Depending on temper
Elongation at Break 50 % 50 % in 25.4 mm.
Modulus of Elasticity 120 GPa 17400 ksi
Poisson’s Ratio 0.3 0.3 Calculated
Machinability 20 % 20 % UNS C36000 (free-cutting brass) = 100%
Shear Modulus 46 GPa 6670 ksi
Thermal Properties
CTE, linear 250°C 16.4 µm/m-°C 9.11 µin/in-°F from 20-300°C (68-570°F)
Thermal Conductivity 45 W/m-K 312 BTU-in/hr-ft²-°F at 20°C (68°F)
Melting Point Max 1020 °C Max 1870 °F Liquidus
Liquidus 1020 °C 1870 °F
