No sound from TMCC engine
Hello, I am not sure (or I could be in denial) but I think I have a cooked sound board on one of my TMCC engines. Everything else works {ie} direction,direction light& strobe on /off, electro couplers. But no bell, horn, diesel motor sound. Who ever can give me the answer? Well I can take it , I’ll just curl into the fetal position and grab my blanky.
[:(][B)][:0][xx(][V][?][?][?]
Does the engine have a battery in it? If so did you do a Shut Down? If this is the case you need to start the sounds by Aux1 +3 to get them on again. Also if this is not the case, exercise the volume pot on the engine. Sometimes they develop dead spots and just a little movement will get it going again.
Try a basic reset with the CAB-1, ENG, #, AUX 1, 0, if this doesn’t work try reprograming per the instructions. If your instructions don’t give the procedure try the Lionel [www.lionel.com/ForThe Hobbyist/GeneralTips AndFAQs/reprogamminglcru2.cfm] or TAS web sites for the method and codes. I’ve had this happen where I lost some of the sounds and this worked.
[:D] Thanks for the information gentleman It works again. I was sweating it out thinking it would have to go for repair.
Jim D.
a.k.a. SOCKO[:D]
So what was the solution? Inquiring minds want to know![:D]
Sorry Marty E,
Your fix was it. Thank you for your time.
Jim D.
a.k.a. SOCKO
