This is going to be a tough one. No message either.
Well, since the details are lacking I’ll just have to make a stab at it. Do you get lights when pressing address 10? For sound: You have to press the red yellow function button before pressing the address buttons that double as function buttons. F8 (mute) may also be turned off.
That’s the best I can do…
Hi there, for some reason my message disappeared. I have the ez command. It has a red stop button and a yellow function button. I press the function button, and i can get the lights the work. But, no sound. I have two engines. One i just added a Bachmann Sound decoder to and the other is new and is a DCC equipeed engine. All the lights work via the function buittons, and all the drive functions work, just no sound.
Which loco is it? What decoder is in it?
David B
Select the engine, hit function, then button 8. On most engines, 8 will turn the sound on and off. I ran my E-Z for 3 years, and it ran all the decoders sound systems I have.
Cuda Ken
Bachmann does not make a sound decoder, and I don’t think they sell the Tsunami sound decoder as an add-on part.
DCC equipped does not mean you have sound in the engine.
What decoder did you use that you say is a Bachmann sound decoder? Unless it had a speaker attached, it is not a sound decoder.
From your descriptions, it seems to me that neither locomotive has sound.
