Noch Grassmaster
My sweet wife gave me a Noch Grassmaster for Christmas. Unfortunately, I have only now been able to try it out. I watched several videos on-line (the instructions with the tool are VERY sparse); looked simple enough, but unfortunately, results were disappointing. While the various videos show the grass standing up nicely (the whole idea), the grass I put down looks more like a thatch rather than a standing field. I thought perhaps the battery was weak, so I tried a new battery - same result. Any suggestions? Thanks, Var
Are you sure you’re using the proper “Static Grass”? These devices use a special product called static grass and other types won’t perform properly.
One suggestion I recall from a video about using static grass applicators was to add a little extra glue around the pin that you plug into the surface. I believe the idea was to ensure a good electrical connection between the applicator and the wet glue surface.
Dave
My experience with this device is that you want to have the tool as close as possible to the ground as you apply. My first few attempts went like yours, with grass that wasn’t exactly standing tall. Once I started hovering about 1/4" over the ground, though, I got the results I was looking for.
I thought the $160. for the Grassmaster was aliitle pricey, so I started to experiment alittle. I bought a container of the static grass, ( about $8 or $9 ), applied the glue, sprinkled on the grass, then took a piece of pink styrofoam board, (lots of pieces laying around from my scenery building) rubbed the surface of it briskly with the palm of my hand, which created a static charge, then I waived the piece of foam about an inch or so over the grass area, and…most of it stood up. What was not in the glue, came up and stuck to the piece of foam. It’s not a 100%, but it seems to work. I haven’t “tweaked” the procedure yet, but for what little I’ve done along some yard trackage, I’m satisfied.
Mike.
Yes, I used the grass supplied with the Noch plus some static grass from Scenic Express - same results with both.
I will try adding more glue around the nail; also, the 1/4" idea seems interesting. Also, I recall somewhere seeing someone suggest adding a little moisture to the grass - can’t find the reference and am reluctant to muck it up. Any other ideas (I am also thinking about trying a humidifier in the local area). I will post a reply once I have tried a few more things. Thanks, Var
Adding more glue around the contact nail was not the answer; getting closer does help, but the results are still not anywhere near as nice as what you see in the videos (e.g., Dave Frary). From close inspection as the grass is deposited, it looks like some of it is coming down at an angle and some vertical (more the former than the latter). If it hits the glue at anything other than perpendicular, it slowly falls over and gets absorbed into the glue. I notice in the Noch instructions that they quite naturally extole the properties of their glue - I plan to get some to see if that will help. So, some progress but still not as nice as what is shown in the pictures and videos.
Var
Keep going and let us know how you do and what the secret is. I would hope that others with more experience will contribute to the thread.
Dave
Var,
I wonder if your device is working properly. I don’t have a Noch, I built one from plans on line. Mine is pretty powerful and it is obvious when it is on. I would imagine that the Noch is strong enough to stand up your grass at a reasonable distance. The videos of it that I have seen seem to confirm that it works much like mine does.
The problem you are having sounds like it could be an issue with the electrical path not making a circuit either in the gun or in how you are hooking it up. I have heard that the Noch guns do eat batteries but it sounds as if you have already checked out that option.
Does the grass stand up at all? There should be an obvious pull from the gun, making the grass stand on end.
Maybe some one with Noch experience will chime in here…
Here are some tips that I learned while using the Grassinator: I’m sure that you probably saw most of this in the videos but here goes:
Decide where you are going to grass and carefully mask off other areas that you don’t want grass particles. I found the particles migrate quite a distance from the application area. You can vacuum up the particles but it is better to not have to do this step. Think Barbershop floor after a long day…The other reason for the masking is that the grassinator sets up quite a strong field and particles of glue covered grass will stray and stick to other objects. They can be a real pain to remove later (voice of experience).
Vacuum the area to remove any dust or stray particles. Later, when you vacuum up the excess grass fibers, you can get a clean pile of grass fibers to re-use if the area is free of debris.
This was my thought as well. I watched a video where a guy tested some home made grass applicators against the Noch. The Noch performed well in the tests but was not the most powerful applicator in the tests. Even still, it was quite capable of applying standing grass.
As for humidity, the drier the air, the more effective the static charge will be.
Guy. I have also see suggestion that you can take something like the foot off of a panty hose and slide it into the vacuum hose … folding the hose opening (panty) back over the hose (vacuum) and taping to collect the excess grass. Ok. Too many hoses there! :slight_smile:
I have learned a lot more since my original post - thanks to all for suggestions (aqnd please keep em comin). A couple of interesting points:
  • I found the reference to making the environment more humid, particularly adding a small amount of moisture to the static grass before adding to the Grassmaster (I agree, it does seem counterintuitive): one of my Scenic Express catalogues had a detailed set of application hints in their section for the Grassmaster. It is a pretty good sequence of hints; I haven’t tried it yet but plan to do so.
  • I spoke to the Technical Representative at MicroMark (where Diane got my present) - I asked him if there was a way to “test” the Grassmaster. He immediately said yes: take a metal spoon, put some grass in it, attach it to the clip lead, and hold up to the mouth of the Grassmaster (without the grid); it should “pull” the grass into the hopper. I tried it and it was weak at best; he has agreed to test the unit if I return it to them. Before I do that, I plan to try the moisture suggestion for completeness.
Stay tuned, I will report more findings, and again, thanks for your help. Var
Another test you could try, although some claim it can be detrimental to the circuit, I have not damaged anything so far by doing it.
If you open the flock jar and position the grounding clip within about 1/8 of an inch of the pointed spike in the base of the cup, arcing should take place between the clip and the spike.
You can test the level of static charge present yourself with a home made foil leaf electroscope. There is a video included with the article linked below that shows this test being done.
Article begins on page 93
Static grass test video on page 102
Electroscope tests on page 121
Static Grass Times 3
Ed,
Thanks for the tip.
Btw: Nice layout site
Guy
This was made using an home made static grass tool. I use glue, paint and matte medium with exactly the same results. What was best to me was placing the applicator 1/4 inch from the static grass material.
