Its not a case of getting panties in a knot or crying wolf. Its a case successful communication and lobbying.
The Congress asked the railroads what would happen, the railroads told them and then communicated the situation effectively, Congress acted in a timely fashoin and everything worked out.
The big communication points the railroads wanted to get across was there were negative consequences to inaction and that the deadline for those consequences was earlier than the deadline for the law.
The railroads were certainly leading the way in the catastrophizing. Catastrophy was their point. And it worked. Someone needs to explain how Congress was blindsided by the amazing turnabout with a mandate that was meaningless.
How will the ECP brake mandate for oil trains be any different? It won’t.
I would say posters on here, none of whom have any influence on the issue, were overreacting. The railroads were using catastrophic threats to get an extension for a deadline they had agreed to.
Poppycock. The mandate had teeth or there wouldn’t have been a need to extend the deadline.
As has been pointed out here numerous times by numerous people, it was found that the timeline was not realistic. Given the amount of lobbying that took place in trying to get the deadline extended, I would opine that the new deadline represents a more realistic goal, and one the industry can attain, or at least come close.
If you have your car in the shop, and the mechanic promises it’ll be ready by COB tomorrow, but then updates you that the part he needs won’t be in until the next day, does that make him a dishonest person? Or is he just dealing with reality, as you would also need to do?
The mandate had no teeth since its inception, and it has none going forward. Extending the deadline was the only choice once it was learned that the railroads would shut down. Extending the deadline was not an indication that the mandate had teeth, as you say. Extending the deadline was an indication that the mandate did NOT have teeth.
If the mandate had teeth, failing to meet the deadline would have placed railroads in non-compliance—just as was intended. Railroads in non-compliance was not originally deemed to mean that their deadline must be extended. If that were the case, what would be the point of a deadline?
Railroads in non-compliance was originally intended to mean that they could be fined from that point forward. Extending the deadline was only needed for Congress to
Hard to make out what the point of Euclid’s post was. It seems to me the original mandate, when passed as a law, was at best a guess for a deadline. It would have been better to give the FRA the authority to modify it without an Act of Congress. It did serve the useful purpose of getting the process of PTC implementation underway. Would that have happened without the law? Impossible to know.
If the mandate had no teeth, and still has no teeth after the extension, than why are the railroads still installing PTC? If they think that one extension would lead to extensions indefinitely, wouldn’t they cut back their PTC efforts?
They have gotten an extension only because they have been making an effort to install PTC. An effort they could not meet in the deadline given. Had they just sat around thinking they could bluff the government into extending the deadline indefinitely, I’m sure they wouldn’t have started putting big money into PTC. And I’m just as sure if the railroads had taken that attitude there would’ve been no extension granted.
Jeff,
You say this: “They have gotten an extension only because they have been making an effort to install PTC.”
I would say that is one way to look at it. The railroads have been making an effort and simply ran out of time. But the ultimate reason for the extension was that it was required to prevent the railroads from shutting down. There was no choice in the matter.
Even if the railroads had not made a good effort to install PTC so far
[quote user=“Euclid”]
Jeff, You say this: “They have gotten an extension only because they have been making an effort to install PTC.” I would say that is one way to look at it. The railroads have been making an effort and simply ran out of time. But the ultimate reason for the extension was that it was required to prevent the railroads from shutting down. There was no choice in the matter. Even if the railroads had not made a good effort to install PTC so far, they would have still gotten the extension because it was absolutely required by the threat of a shutdown. When I say that the mandate had no teeth because its deadline could not be enforced, what I do not know is when this became apparent to the railroads. They only began talking about it a couple months ago. Maybe most of the seven years so far, the railroads never considered that the not meeting the deadline would lead to an extension. So maybe they took the deadline seriously enough to be motivated to spend money on PTC. Or maybe the railroads would have just gone ahead and installed PTC because the government asked them to do it, and so there was no actual need for a deadline. But somewhere in the past, Congress must have concluded that the only way we would get PTC was if they mandated it. But whatever was thought about the mandate so far, going forward, all the players know that there is no deadline that will stand. So we will soon find out whether the railroads will make progress without a deadline. The underlying premise of a three year extension is that most of the work is done, and only three more years is needed. Yet, they appear to have gotten into the phase where new research and development is needed, and nobody can predict how long that will take. The cost overruns of the unpredictable R&D phase may require a lot more expenditure than what has been done over the last seven years. So it will be interesting to see
As noted, just like everything in life. In fact, it would still be true if PTC was able to be fully implemented by the end of the year.
Once PTC reaches full implementation, the technology will continue to develop. New methods of completing the same tasks will be found, equipment will be improved, and new requirements come to light after the next Chatsworth.
You are fixated on the mandate having no teeth, yet it did have teeth, and still does. Discretion being the better part of valor, those who could enforce the deadline chose instead to react to the reality of the situation and move the target.
As has already been pointed out, work was begun - and continues - on the implementation of PTC.
