Northeastern Scale Models Instructions
I recently bought a older Northeastern Scale Models (Ambroid) Russell “Winged” Snowplow, and when I got it, I found out it doesn’t have instructions with it. Is there anyone out there who has this plow, and still has the instructions? I would be really interiested in your inquires if you still have them.
Thanks
Phil
Phil, One thing you might try is the index of magazines linked at the top of the forum page… A lot of times, these kits were based on plans drawn for publication or aren’t too much different from such… The drawings may help if you cannot locate the actual instructions which, if I remember correctly, weren’t much more than drawings to begin with…
Good luck,
Jeff
Thanks Jeff, I took your advice, and found out that the December 1986 issue of RMC has a feature article on building and upgrading the plow. Now I just have to find it. I’ll check RailPub, as they probably have it.
Thanks again,
Phil
