After a close to $500 outlay for a Super Empire Builder Xtra kit, PS 514 power supply, a couple of AR1’s, extra UP5’s, a PM 42 and PS14 power supply for it, I began mounting the components yesterday. Right off I found out:
(1) the PS 514 power supply is a 4 amp max vs. a 5 amp capacity as sold,
(2) the user manual is outdated (2009 last revision) and still references the discontinued PS 515 power supply with the higher 5 amp max output in numerous instances,
(3) the attached sticker on the enclosed card in the PS 514 bubble pack notes to use the “white” adaptor banana plug with the pig tail that connects the power supply brick to the DB150 which, following the instruction, proved wrong where the inside diameter of the white adaptor banana plug is too large to make contact with the center pin of the pig tail connector.
I called Digitrax support this morning and the response I got was "oh, well, just use one of the adaptors of the included set that will fit. Well, gee… no kidding there Dick Tracy. And when I questioned the updated PS 514 version power supply having a max amp capacity of 4 amps instead of 5 amps with the PS 515 it replaces as referenced throughout the user manual I got a “yeah, I’ve talked to engineering about that and…”
I know all of this may sound petty on my part but from a first time DCC user standpoint where it not for the fact I have an electrical background I’d have been in trouble from the get-go with no power input to the DB 150 following the printed Digitrax hookup instructions for the PS 514.
And from reading up on the PM 42 I already know the Digitrax&
