A couple months ago, I got a Proto 2000 FA2/FB2. The FA2 unit was extremely noisy and slow. In fact, it was so slow, that the FB2 would lap it every other lap. This is not acceptable for an MU. The FB2 unit had a short and blew out 2 decoders. I called Life-Like and told them the problems and they told me to send the units in. I sent them in with the decoders as well as the replacement boards they sent to me.
I got them back today with the following letter:
Dear Mr. Englemann,
We are returning your locomotives without repair.
We can only in this case, provide you with replacement PC boards as we have done to return your loco to their original configuration. I’m sure you can understand that Life-Like cannot undertake to install, check out the operation and warrant decoders made by other manufacturers.
Since you are using Digitrax decoders, we strongly suggest that you contact their tech support folks for help in solving the operational problems you are encountering.
The noisy running sounds as if the motor shaft bearings need some lubrication. These are the bearings at the end of the worm, and where the shaft exits the motor housing.
Regards,
Chuck Frieldlein
manager, Product Development
Life-Like Products, LLC
Now I understand that they would not want to mess with the Digitrax decoders. But it seems to me, that if they knew that PC boards were bad and had them in their hands and they knew that the noise was caused by the motor shaft bearings, that these problems could have been handled. Problems that should not exist in a new engine.
But not only did they take a month to do nothing, they did not send back the replacement boards nor did they send back the Digitrax decoders. So not only am I no closer to solving the problem, I have to re-obtain the replacement boards and decoders.
When I called to get my decoders back and re-obtain the replacement boards,
