“Recklessly endangering another person…” sounds a lot like they are charging him with endangering the conductor…kinda silly, kinda not if that’s all you can come up with.
But, and this is a big but…the part of risking a catastrophe might stick, especially if the “opiates” turn out to be coke.
As for the “Benzos” so quaintly put…as long as the superintendent is made aware of an employee using a prescribed drug to treat a recognized illness, and that drug is FDA approved for use in the environment the employee works in, there should be no problem.
Lots of railroaders, and a lot of everyday folks use the stuff with no ill effects.
If, on the other hand, he had boosted some illegal meds, taken something without a prescription, on top of a little nose candy, then he should be run off permanently and if the local DA wants to press charges, then the engineer has no recourse.
I don’t like working around anyone who is under the influence, be it booze or drugs.
As for the conductor, if he has 8 months total, then subtract 3 months training to get over his derail…maybe 2 months as a brakeman or switchman, which leaves 3 months as a certified conductor.
If the hogger was a lot “older” then the conductor, I can see where the conductor would not realize how much trouble they were in until it was too late to do anything but ride out the pucker time and hope you live through it.
All of this is based on a news release and a newspaper report, of course, so until the FRA releases its findings, we are just guessing.
And remember, they guy is innocent until proven guilty, so…
