We all know about NS’s program of rebuilding spartan cab SD60s into SD60Es with NS’s own-style wide cab. NS is now rebuilding a former CR spartan cab C40-8 with a comfort cab that’s similar to their SD60E rebuilds. So it looks like NS is planning on rebuilding their spartan cab GE’s with wide cabs too. I wonder if at some point NS’s standard cab SD70s and C40-9s will be getting SD60E-style wide cab rebuilds too?
On this forum and others some have charcterized dash 8’s as being junk, “toasters”, slow loading, no loading, and only worthy for the scrap line. NS does not spend money foolishly, so why would they bother with this project?
I wish they would keep the standard cab. I think it looks a lot better. But I can imagine the crews like the new cabs a lot better. I’m sure they have more room and are more comfortable.
It’s a no brainer as they say, Dash 8’s were great locos, it was the series that got them ahead of EMD.
Also makes a mockery of the old, you can’t rebuild a GE line that seems to come out every now and then!
The Dash 8’s were the first GE locos in Australia and they are still going strong and the reason that nearly all the ralway company’s are now GE customers!
The issue of 'not being able to rebuild a GE may have been more of a commercial issue,i.e., the availability and cost of needed material.
Given GE’s current market penetration, there may be more current interest in development and marketing of rebuild kits for the later Dash8’s and beyond.
I agree that the Dash-8 was the locomotive that put GE in front. But, they still have the old FDL prime mover - I know of no EPA ‘part 1033’ upgrade packages to brings this into emissions compliance. I can see upgrading EMD locomotives that have a ‘710’ series power plant as it can be upgraded(like the SD60). Both UP and BNSF have dumped older GE’s of this lineage to CN as the Canadian emission restrictions do not cut in as fast. UP has a test program where older SD60 series locomotives have been upgraded with a V12-710ECO package.
There is a CFR 1033 package out there for Dash-8 GE. Both CN and CSX are installing them. Look for the radiator shutters mounted on top of the Dash-8 radiators as the most visible spotting feature.
In the photo the rectangulat items above the radiator look more like additional radiator cores for intercooler cooling rather than shutters. For a start shutters would have to cover the whole area of the main radiators to be effective and there wouldn’t be any advantage to a split cooling system to add shutters…
Most of the old dry type rads on the toasters are being converted to the wet type used by EMD. Reason being they are not near as prone to cracking in the winter when you pump 200 gallons of 210 degree water into -20 degree metal, as well as the safety aspect, if you open the water tank on a GE with dry rads when they have water in them the water has a nasty tendency to come spewing out at you with more velocity then you would imaging possible.
I think you are right. Has to be retrofit split cooling to keep charge air cool and lower NOx emissions. Looks like they just kinda slapped them up there on top of the existing cores.
Don’t GE radiators have a silicon joint between the tubes and headers…or am I thinking about something else… It was to handle the thermal issues. I don’t remember the Conrail GEs having radiator issues, but there were enough other issues to keep us busy!
EMDs radiators didn’t fare well with soldered tube to header joints until EMD went to mechanically bonded cores - problem solved!
