NTSB: Canadian National failed to warn train before derailment
Interesting but the CN dispatcher phones put you on hold. You shouldn’t get a busy signal!.
We need more railfans with RR radios, red flags and fusees.
BTW if you see this sort of thing. Send someone 1 mile on either side of the washout and place a fusee or red flag or wave your hands wildly as a train goes by. All of those are signals to stop.
Pretty clearly the problem is in CN’s communication system and over-centralization. Emergency phone calls should not have to go to Montreal and then to Homewood.for action (Perhaps the Homewood folks resent control in Montreal?). Or if CN insists on this system, Montreal should be capable of communication to loco crews directly. 17 minutes and nothing done. The response took 21.
Yes that is what Kate Shelley would have done in the age of self-reliance and rugged individualism. But this is the Decade of Gotcha!
So if you were to take that responsible course today of flagging the train, you would probably get an unexpectedly speedy response from Homeland Security, the FBI, the local police, and the railroad police—all reading you your rights—as the train piled up in the background.
Do you believe that Bucyrus, or are you just trolling?
Sometimes I can’t tell with you.
As far as I am aware all the railroads do it the same way, just that the others have better internal procedures. And better communications systems.
It must just be the way you are looking at it.
Over-centralization has nothing to do with it. My carrier has exactly the same setup at the one BaltACD describes on the last page, with the police being located in Florida and the dispatch center located just outside of Chicago. There is no lag in notification, as any dispatcher will drop what they are doing to answer the hotline. Why the CN does not have a hotline between the police center and the control center, I do not know, and I hope that one is being installed. As far as the police being able to contact the trains directly, you do not want that. ANYTHING having to do with train movements on the main line needs to come from one voice, one person.
I would be inclined to think that this is one case where “centralization” (of dispatch operations) would be better. It would be easier to have a well manned office to receive the emergency calls just down the hall from the dispatch center. If all other methods of getting a phoned in alert to the appropriate dispatch desk failed, the message could be delivered in person-perhaps with a few well chosen words not appropriate for a family forum.
  1. I did not suggest police contacting the crew directly.
  2. The CN system may be the same as others, but it did not work in this case because of breakdowns in the chain of communication. If that isn’t obvious, then there really is something fundamentally wrong.
  3. CN’s problem is that the central location (Montreal) could not get the dispatch center (Homewood, IL) to answer the phone and Montreal thus had no way to reach the crew. There should be a back up system in case normal channels break down.
Centralization has nothing to do with it. Lack of effective policy, procedures and hardware implementation within CN has everything to do with it. The police center in Montreal should have had a dedicated Emergency Line that the police center and the police center ALONE have the number to and that line must be restricted from being able to place outbound calls. There should NEVER be the occurrence of the line ringing busy, being placed on hold or not being answered. The police center should not be directing calls to any trick dispatchers desk (note - the phone systems in today’s environment for most trick dispatchers will automatically answer a call after two rings and place the call on hold on the dispatchers console until they have time from their other duties to answer the call). Emergency calls must go to the Chief Dispatchers console and it must be ingrained for the Chief Dispatcher to answer the Emergency Line as THE PRIORITY MATTER of his job. Once the Chief Dispatcher gets the notification they can break into the appropriate trick dispatcher work stream to start the emergency ball rolling ie. stop trains approaching the affected area and take any other steps that may be necessary to protect both the carrier and the public.
Giving the public a single call center, no matter where it is physically located, enhances the overall response time to the emergency. In many cases the public may have numbers of yard offices, crew rooms, mechanical shops and who only knows what number that they consider ‘the number’ when it comes to contacting the carrier - calling any number other than the designated emergency contact number will only slow down the response and create unneeded confusion in handling the emergency situation. Getting the public to call the correct emergency number takes a concerted effort by the carrier over a long period of time to get the number out to the public.<
  1. You kind of did. IF the CN is anything like my railroad, the people on the line in Montreal ARE police. They are railroad police. By saying that Montreal should be able to talk to crew directly, I took it as the CN Police Command Center in Montreal should be able to talk to the crew without the dispatcher involved. Which is a bad idea. Was that not what you where implying?
  2. I have not seen anyone say that there wasn’t an issue with communication, that was the main cause here.
  3. Again as pointed out, there does not seem to be a hotline for the police center to get a hold of the dispatcher center, it seems as they are just calling on a normal Bell line. That is THE issue, and I think a hotline, and its use, would have stopped the whole thing from happening.
Someone mentioned the possibility of flagging down the train. And yet it has also been suggested that only the proper authorities should be allowed to contact the crew. I believe that any way to get the message to the crew would have been just perfect for an emergency such as this one.
A police officer was the first authority to confirm this emergency by direct observation at the scene. He recognized the danger to a train and had no idea when one would show up. He could have turned on his flashing lights, and lit up some fusees just to buy some time. He could have called for more backup on the scene just to help get a warning established. I don’t know how much straight track visibility they had there, but a lit fusee at the washout would have gotten the train stopped short if the track was straight long enough to see the fusee and stop.
@n02944: I thought you were referring to the local Cherry Valley police trying to contact the crew, though I doubt if that is possible. So if the Montreal number is railroad police, with the CN they seem to have no backup plan to get hold of the necessary folks in Homewood. But wouldn’t it be better for the CN railroad police to advise the crew than to not reach anyone and just let stuff happen?
So tell me, how does the CN police know there is a train in the area? Again, a simple hotline to the dispatch office, with instructions that when it rings you stop what you are doing and pick it up, is all that is needed. There is NO reason to have the police giving instructions to the train crew if this policy is put into operation.
They would have no situational awareness. i.e. what radio frequency, which tower to activate, what train or trains need to be contacted, etc. The Dispatcher would know all these things. Fixing the communications link between the Police Call Center and the Dispatch Center is a much more straight-forward solution. The reason for having the calls go to the police center is to filter out the calls from irate citizens calling to complain about trains blowing their horns at night and similar. Having the Call Center adjacent to the Dispatch Center is a good idea, if the company has centralized their Dispatching. However I don’t think any company is fully centralized at this time. CSX was until the Conrail split-up.
CSX has always maintained a dispatching center in Chicago, as well as Wallaceburg, Canada.
It is also an indication of incompetence that CN/IC did nothing given the repeated problems with flooding over the past few years. Of course, Homewood Dispatch should answer the phone. But I believe all Montreal got was a busy signal for 17 minutes. Since Montreal has no knowledge of where crews are, then it is essential to have a back up plan for Montreal to use when they cannot get through. If not, as someone said earlier, the prospect of loaded CN/IC trains running through urban areas, like suburban Chicago is disturbing.
Back when I was still a conductor, our dispatcher notified us that a person had called our RMCC (the phone number on the signal boxes) and reported our train had a container on a yellow flat car with the doors open and spilling it’s contents. When notified we were about 25 miles from the place where the person had seen this. At least 25 minutes, probably a few more, would have elapsed from the initial spotting to the info getting to us. Allow maybe 10 minutes in case the person didn’t have a cell phone and had to find a land line still leaves15+ minutes from the railroad receiving the call and the info getting to the crew (us).
I inspected our train and found a yellow flat car with a load of sheet steel, a few of which had shifted forward out over the couplers. We didn’t have any COFC in our train to begin with. That means that somewhere along the line the report changed a bit. Someone misunderstood what the problem was. Either the person reporting or the person taking the call. (I’ve always felt the person reporting was someone I knew who was a retired railroader, but not from the CNW or UP. He’s passed on and I never remembered to ask him. I know he could tell the difference between a container losing it’s load and a shifted load, but I’m not sure the person answering the phone at RMCC could. Just because a person works for a railroad doesn’t mean they are familiar with railroading in the field.) In the CN case, I would like to know what was said by the civilian police to the railroad police, and what they said to the dispatcher’s office. I can’t imagine that there could be any misunderstanding about a washout, but you never know.
About having th
I guess someone has to get the word out.
"Investigators also focused on CN’s procedure to warn its trains of inclement weather. Two hours before the derailment, forecasting service AccuWeather issued a severe flood warning for the Freeport area, including Rockford. The alerts come to the Homewood dispatch center via a dedicated printer equipped with an alarm bell to alert staff of the weather report.
That night, however, it’s unclear when the report was delivered to Darnell Parker, the dispatcher in charge of the rail lines around Rockford. Parker never relayed the report to the CN train as it approached Rockford. It’s unclear what effect the warning would have had on the train, as CN procedures only call for engineers to be cautious in light of a flash flood warning, not to stop the train."
  1. Flooding happens, not an indication of incompetence at all. To me, the incompetence would be the association that knew of the damage to the pond wall, and had not fixed it. Your dislike for the CN is showing and clouding your judgment.
http://www.rrstar.com/news/trainderailment/x65589116/Damaged-pond-wall-Group-was-working-on-it?zc_p=0
  1. There has been no indication that the Homewood office did not answer the phone on purpose. It is very possible that the dispatcher was busy enough on the radio, or on other phone calls and was not able to get to the phone in time. Again if there is not a emergency tone, so the dispatcher KNOWS it is an emergency, most dispatchers will answer the radio/phone in the order that they come in. In this case, with no emergency tone, the dispatcher does not know if the call is about a washout, or a yardmaster looking for a headroom shot out of the yard.
  2. Again, a hotline from the police command center to the dispatch office is a plan that works, and I am willing to bet that one has been installed as a result of this accident. I am not sure why you fail to accept that fact, especially when two dispatchers have told you in this threa
