Lionel 6-14552. Has anyone replaced the bulb inside the cab? Is the bulb soldered to the board or is the bulb connected with a wire nut? I asked Lionel but they weren’t sure. My next step is to remove the shell but I thought I would ask here first. Thank you.
Sounds like they’re LED lights soldered to the board from what I read in the manual on the Lionel website. They recommend you send it in to have them replaced unless you feel confident you can replace them yourself.
SantaFe158, thanks for your reply. The lights in the cab are bulbs.
