I have the Edson, Vail, Smith NYC diesel book in front of me and the builder’s photo definitely shows Dupont Duco Black Lacquer No. 254-2234.
Sometimes a builder will overspray with dark gray for just the photo shoot but not in this case. There may have been variations (like the olive green for the P&LE) but it is a pretty safe bet these engines wore black for their entire lives.
There’s a fuzzy copy of the same builders photo of DRS-7 #7000 here:
Thanks for the links and info, Ed. It’s the exact same pics I looked over before posting the thread. The only thing I didn’t have in front of me was the NYC diesel book you mentioned because it was back in PA.
Perhaps it’s just how Atlas photographed it. Or, maybe it’s supposed to be a “faded” black? The Atlas 2003 releases are listed as “Black/Gray/White”. The 2014 releases are listed as “New Paint Schemes!”??? [:S]
All the b&w pics I’ve seen on Fallen Flags (one dated '52) show what appear to be a faded (oxidized) black. I’m guessing that that’s the look that Atlas was trying to achieve???
Thanks, too, for your link, Bear. At the very least it looks like a dark gray vs. a lightish gray.
I’m pretty sure the model is supposed to be gray, not faded black. The black ‘lightning stripe’ paint scheme was for freight engines. This scheme, the dark gray ‘lightning stripe’ was the passenger scheme, like E-units or passenger F’s would have.
Like many railroads, NYC bought more passenger diesels after WW2 than they turned out to need. It could be these engines were delivered as passenger engines (like for commuter trains or branchlines) in the dark/light gray scheme, but after a few years were changed to freight engines and repainted into the black ‘lightning stripe’ scheme. I’m pretty sure they did that with some of the passenger GP-7s.
You might try posting this on the NYC forum on railroad.net for more info…
No reply yet from Railroad.net. I also posted the query over at one of the NYC Yahoo! Group fora. The only answer that I’ve gotten so far is “some were black, some were gray”. I hoping get some road number specific info to elaborate on that.
According to “Diesel Locomotives of the New York Central System” by Edson/Vail/Smith, NYC 7000-7003 were equipped with “Layover Heating” during 1952-53. I assume this was a steam generator of some type - I know some switchers had small steam generators so they could heat up passenger cars while waiting for the road engine, like when trading engines at a division point. It may have been something like that, although those engines had dual controls so could be easily worked in either direction…so may have been used in commuter train service.
Anyway, my guess would be those four were the ones painted in the passenger scheme - although the book’s pic of 7000 on page 95 shows it in black, in what is apparently either a builder’s photo or a photo taken at or near the time of delivery in 1951. I also suspect that by the time the simplified “cigar band” scheme came along in the late fifties, they had already been converted back to freight engines.
It is my understanding that “Layover Heating” is a coolant heater and circulator so that the engines can be shut down in freezing weather and the heater would keep the coolant and oil warm enough to prevent freezing and the oil warm enough to make starting easier.
Normally the diesel fuel was cheap enough then that they were left to idle the whole time but these must have been in service where they were shut down for, say a weekend.
Not saying for certain but that’s my take on the layover heater.
If you havent already purchased one, NYC Power in color Vol 2 (#4000-9820) will be available next month. Should hopefully have at least one photo in full color.
The last one had a photo of an F7 in North Vernon, Indiana, where PRR, NYC and B&O all once met. Now the B&O (CSX) and the PRR tracks exist in that town, with the PRR being truncated to about a mile or two in length on either side of the diamonds for a local industrial switcher to feed cars two to and from the main.
I just picked up Vols. 1 & 2 of “New York Central Power in Color” and they are going to be a very nice addition to my NYC reference library. Thanks for the recommendaton! [:D]
I looked through Vol. 2 and every lightning-striped H16-44 (& H20-44) that I saw was either black or a charcoal gray; NOT lighter gray. Same with the RS-3s. So, I don’t know where Atlas got their info but it’s a foobie in my book - unless they were going with a weathered black appearance???
Anyhow, I ended up picking up a first-release (2003) of the Atlas H16-44, which is in black and very handsome looking.
As mentioned previously I picked up Vols. 1 & 2 of “New York Central Power In Color”. Browsing through it last night I found a few references to a “light gray paint scheme”. According to the author, Jerry A. Pinkepank, the gray paint schemes “were applied to many locomotives that were delivered or got heavy class repairs in late 1955-early 1956.” (See Vol. 1: SW1, pg. 25; VO-600, pg. 28 & Vol. 2: GP7, pg 38)
So, it looks like my previous conclusions about the 2014 release of the Atlas NYC H16-44s being a foobie were ignorantly erroneous and the lighter gray would be correct for a NYC post-1955 delivery or post-class repair paint scheme. That leads me to another question, or set of questions:
What would constitute a “class repair”? Would this be a correction to a well-known problem within a class of locomotives? Could it also be a general improvement or enhancement to an already well-designed locomotive or class of locomotives?
My understanding is that the “classes” of repair came out of a USRA “streamlining” of shop facilities in 1918 in order to make more efficient use of duplicate services and keep more locomotives “on the road”
USRA and later the ICC established “levels” of repairs in order to classify their needs.
USRA (1918) :
Class 1
New boiler of back end
Flues new or reset
Tires turned or new
General repairs to machinery and tender
Class 2
New firebox or one or more shell courses or roof sheet
Flues new or reset
Tires turned or new
Class 3
Flues new or reset (superheater flues may be excepted)
Necessary repairs to firebox and boiler
Tires turned or new
Class 4
Flues part or full set
Light repairs to boiler and firebox
Tires turned or new
Necessary repairs to machinery and tender
Class 5
Tires turned or new
Necessary repairs to boiler, machinery and tender
including one or more pairs of refitted driver
bearings
General Repairs to Machinery
Drivers removed
Tires turned or changed
Journals turned if necessary
All driving wheel boxes and rods overhauled for a full
term of service
AAR (1924)
Class 1
New boiler or back end
Flues new or reset
Tires turned or new
Class 2
New firebox or one or more boiler shell courses new,
or wrapper sheet new
Flues new or reset
My take on ‘class’ or ‘classified’ repairs was a list of items inspected, renewed, or replaced on a normal shopping interval or due to wreck repairs.
There might have been a ‘program’ to upgrade an entire model of locomotive, but usually that was a 60’s thing for the most part. I can think of the NP Baldwin switchers or the some early Alco power that got repowered. EMD usually put in a bid to repower the engines, as well as a sweet trade-in/financing package on new EMD replacements that sent the old engines to the scrapper…
And I would tend to agree, Ed. From the pictures I’ve found so far I’ve only seen black paint schemes on the NYC H16-44. To give the author the benefit of the doubt though, he did say “many” but not all. Maybe he elaborates on that a little more in another portion of one of the books.
