Hello, I’m new to train collecting and have just purchased a wonderful Lionel Great northern 4-8-4 locomotive which states 0 and 027 guage on the box. I also have about 14 cars of rolling stock also o27. I eventually want to build a two train layout. Can I mix and match or will the size difference be too noticeable? I’ve seen some MTH O guage locomotives but I cant seem to find out what the difference is. Thanks for the info.
Hi Jimkat,
027 and 0 mix up well as far as the rolling stock goes. Sometimes 027 is a bit smaller (postwar) then modern rolling stock, but as long as you don’t mix too different sizes in one train, it’s hard to tell the difference. The main difference is in the hight of the tracks. 027 track is about half as high as 0 track end also the rail itself is narrower in size (so the track connecting pins don’t fit between 027 an 0 and vice versa)
Also 027 is the size of the smallest curve, which is 27 inch in diameter. The 027 rolling stock will negociate that curve without any problems, but the modern 0 gauge stuff requires 031 (so 31 inch diameter) for the narrowest curve to negotiate.
In the postwar time Lionel used 027 as a mark to tell that it is not truly a scale locomotive, but it’s sized down to handle the sharp curves and therefor the size of the engine and rolling stock was somewhat smaller then the scale of 0 gauge would expect them to be.
However, when you start from scratch, it’s best to use 031 or 042 size curves as a minimum, because with that you have choise of all kinds of riolling stock, in 027 or scale size.
Both curve diameters are available in 0 and 027 size track…
welcome to the site. My advice with collectiong your trains is “Have fun with them” You can mix and match O and O27 engines and rolling stock as long as you don’t get caught up “counting rivets” Some people want every detail to be just like the real trains. That’s fine for them. I collect what I like, oversized Lionel acessories, different sized rolling stock, etc. I’m reminded every time I look at my prewar V transformer that says “Toy” on it.
There’s absolutely nothing wrong with either approach to 3 rail O-Gauge. It really depends on what turns you on. There is only one directive–have fun. Layouts can be toy train, hirail or somewhere in between. It’s up to you.
However, in answer to your question, “Can I mix and match or will the size difference be too noticeable?”, the answer is the size difference will be noticeable. Scale sized rolling stock will typically be higher, wider and longer than traditionally sized O or O27.
Did your set come with Fastrak (built in road base) or is it tubular track? If it is Fastrak, it actually has 036 curves and will work with almost all engines and rolling stock.
The cars may work on 027 but are probably “traditional” sized which is bigger than the smallest cars but smaller than “scale” cars. You will find they look fine with anything that is not “scale” sized. Try taking a car to your local hobby shop and see how they compare. Your cars will work well on any 3 rail track.
Jim H
As far as MTH goes…anything marked “Premier” will probably be scale and noticably larger. Rail King stuff is smaller (unless it is specifically marked scale).
Jim H
Welcome jimkat.
It sounds like you have a pretty good collection there already. I ordinarily try to avoid mixing O27 with my more scale sized equipment (exceptions being Lionel’s Hi-Cube boxcars and auto racks). The O27 rolling stock tends to look too diminutive. But, since you are thinking two train operation, might I offer the advice of running your O27 equipment towards the back of your layout, or on an upper level (which would facility return loops with O27 curves).
…and the biggest piece of advise that I offer all my friends, is avoid the temptation to buy everything in a bright orange box. Give some careful thought to the type of layout you want to construct. Include accessory placement, or an industry siding, a region, a season, and possibly an era.
Best wishes, and remember the fellas on this forum are a valuable resource.
Jimkat,
The terms O-27, O-gauge, O-scale, and Standard-O* cover a confusing mare’s nest of sizes and designs. The one constant among them is that the distance between the outer rails is always the same, so the wheels will always rest on the track. However, the the rate of curvature of the track, and consequently the locos and cars that can run on them, can vary all over the place, as can the sizes of the locomotives and cars – within limits. These variations can make for important differences in operation and appearance.
Operationally, the limiting factors revolve around (1) the requirements of the largest locomotive and (2) those of the switches (turnouts). As a general rule: the wider the radius of the curves, the better things look, assuming you have sufficient space in your train room to allow it.
The rate of curvature is customarily described as the diameter of the tightest possible circle of track of a given specification; i.e., 27 inches, 31 inches, 36 inches, 72 inches, etc.
As long as the rate of curvature of the track is large enough, any of the O-gauge family of locos and cars will run on the same layout. The fewest locos/cars will run on the the track with the lowest diameter, 27 inches. Virtually anything will run on track of the greatest diameter, 96 inches or more – and be and look “comfortable” doing it.
Everything being talked about here is “three-rail,” also occasionally referred to as “tinplate” or even “Lionel,” even though there are many other quality manufacturers. (There is also two-rail O-gauge, but it is not compatible with three-rail, at least as far as anyone new to the hobby is concerned.)
Within the constraints noted above, you can mix and match at will. The only determining factor is appearance. If you put an O-scale boxcar next to an O-27 boxcar, the O-
O-27 simply means that it can run on 0-27 curves and is built slightly undersized and not 100% to scale to be able to do so. O means that it is scale and most often cant run on O-27. To answer your question, yes you can run the two together. I do it all the time. Just take into account that you must use O GUAGE track to do so and not O-27, as the scale trains are inoperable on such tight curves.
“O means that it is scale and most often cant run on O-27.”
The above statement is not entirely correct. Let’s put it this way–any three rail rolling stock listed as scale or “Standard-O" is built to scale dimensions. However, just because something is listed as O doesn’t necessarily mean it is scale. As others have said O is typically larger than O27 and may not be able to negotiate a 27” diameter curve.
The best thing to do is ask someone to show you the size differences. It can be confusing until you see them next to each other.
There is no hard and fast rule. There is stuff that was sold as O27 that is built to scale. There is stuff that was sold as O (now often called “O31”) that is not built to scale. There is only the generalization that O tends to be closer to scale and more expensive than O27.
The diameters of traditional tubular track are measured to the outside ends of the ties, not to the center of the track. Thus the actual diameter of O27 is 25 inches, because of the 2-inch ties, and the radius 12.5 inches. O ties are 2.25 inches long; and the actual radius is 14.142 inches; so its really about O30.5 (and is in fact sometimes called O30).
O27 type track can be found not just in the 27-inch diameter but also O34 (old Marx) and O42, O54, and O72 (K-Line).
My personal obsession is modifying stuff to run on O27 that was not meant to.
Thanks for the informative reply. I’m using O gauge track that I put around the xmas tree. I appreciate the help this forum offers. Happy New Year to everybody!
