O Gauge Garden Rail Roading Track: Lionel 0 Gauge vs MTH O31 vs Atlas Stainless
Good Afternoon,
We live in Minnesota - variety of weather conditions: Hot, Cold,Wet, Dry!
My son and I as a Boy Scout Merit Badge Project are expanding our present O-Gauge Lionel MTH Consist to a 'Covered" Outside Garden Railroad. We also have a variety of inherited Lionel and K-line Engines, Cars, Track 1960-2005
Ours will not be the traditional ground level garden railroad. We will using our old 10 x 5 table that has been marine varnished top/bottom/ adding boulders, bushes, … around it to make it more realistic.
It will be about 25 inches high off the ground. two long runs, 3-4 Various Switching and Turnouts …
It will be covered at night or when not in use with ground cloth.
Question(s):
1). We have alot of extra MTH Real Trax O-31, O-42, We would like to use this track to cut down on cost to build Can this be used outdoors with wd-40 or will it rust?
If it is prone to rust. How long before it may begin to rust heavily? Months, Year (s)?
2). We also have a lot of 1960’s (Rusted , yet cleaned (bright boy) Lionel O-27 track and switches. Could this be used or combined with MTH Real Trax?
3). Everyone we have talked to suggests stainless steel O gauge (Atlas …).
This railroad may be outside around 1-3 years. Would the MTH Real Trax or Lionel O-27 last that long?
4). We have older 0-27 Lionel (refurbished) Engines that we would like to run on this railway. Can our Rail King Engines or Premier Engines Run Outside during good driving conditions on O-27.
Any Suggestions regarding our O-gauge Outdoor Rail Road would be helpful.
Thank all for your time and consideration,
GrandmasterII
Have not done it myself but Gargraves makes stainless steel track with ties that are UV resistant Gargraves will mate up with 0-27 track with adapter pins sold by gargraves.
A note about power packs/transformers mine overheated on my front porch in 90 degree weather so if you run make sure your transformer is over rated so it is not taxed to the limit.
CsKect, Thank you for the Reply. The Scouts have decided to experiment with one section of each track we presently have O-27, O- gauge (tubular); MTH Real Trax leaving them outside to see what happens . Thus opening a whole new arena for learning Who takes care of track, What causes …, When does it need to cleaned Where: Does Shade help…? i.e. oxidation, warping, is there a film of dirt on the track … How did it get there, What can be done to clean the track …
Thanks Again - Have a Great Day!
Grandmaster II.
Was a scout off and on in my youth, the older I got the less I stuck with it. I kinda wish I had given Explores a try. I think I made it as far As STAR. I was picked a few times to become part of the order of the arrow but turned it down as I was losing interest in scouting. Will have to look and see if I got the Model railroader bage I still have the book on the badge and how to get it.[:D][8D]
