Yesterday, I successfully converted my first locomotive to a new type of “command control” system used by millions of Americans, but almost nonexistant among toy train operators: remote control or R/C, not command control like DCS, TMCC or DCC which depends on rails for power or signal but R/C like that used for model boats, airplanes and racing cars everywhere.
I will show some photos and diagrams, try to explain the process in simple English, and give what I think are the pros and cons of doing this procedure. First, I want to make it clear that I’m an electronic klutz, so if I can do the
conversion, anyone can. Without the help of Austin, Texas resident Jim Duda, none of this would have been possible. We spent time emailing and on the phone, as he walked me through the procedures step by step. Thanks, Jim.
Now for the pros and cons. Keep in mind that I made the conversion less than a day ago so the information I’m providing will be incomplete, as there are many more tests to run and it is likely I will be experimenting with new types of R/C gear in the future, so I plan to use this thread to give updates (which might occasionally be few and far between, as I’m also building my outdoor layout simultaneously).
Here are some factors to consider when deciding if R/C is right for U:
If you have a layout already wired and are happy, this procedure is probably not for you; especially if you already are using some type of command and control system.
R/C conversion isn’t free, but neither is it expensive. The 3 main components: 1. onboard battery pak with charger; 2. transmitter/receiver; and 3. electronic speed controller or ESC; cost, all together, about $100. It is possible with just this gear alone, to power all of your trains, including even the Beep and Plymouth Switcher and 0-4-0, if a trailing battery car is used (converted boxcar, gondola, etc).
TIme of installation is also a factor. Once U know how to do the procedure, howeve
