I made a post to a blog entry in the Observation Tower blog.
When pressed the ‘Submit’ button on the post I got the following Error
"Unable to connect to commenting service.
Quartz.JobPersistenceException: Couldn’t store job: Could not allocate space for object ‘dbo.QRTZ_DYNAMIC_JOB_DETAILS’.‘PK_QRTZ_DYNAMIC_JOB_DETAILS’ in database ‘prod_Community_TRC’ because the ‘PRIMARY’ filegroup is full. Create disk space by deleting unneeded files, dropping objects in the filegroup, adding additional files to the filegroup, or setting autogrowth on for existing files in the filegroup. —> System.Data.SqlClient.SqlException: Could not allocate space for object ‘dbo.QRTZ_DYNAMIC_JOB_DETAILS’.‘PK_QRTZ_DYNAMIC_JOB_DETAILS’ in database ‘prod_Community_TRC’ because the ‘PRIMARY’ filegroup is full. Create disk space by deleting unneeded files, dropping objects in the filegroup, adding additional files to the filegroup, or setting autogrowth on for existing files in the filegroup. at System.Data.SqlClient.SqlConnection.OnError(SqlException exception, Boolean breakConnection, Action`1 wrapCloseInAction) at System.Data.SqlClient.TdsParser.ThrowExceptionAndWarning(TdsParserStateObject stateObj, Boolean callerHasConnectionLock, Boolean asyncClose) at System.Data.SqlClient.TdsParser.TryRun(RunBehavior runBehavior, SqlCommand cmdHandler, SqlDataReader dataStream, BulkCopySimpleResultSet bulkCopyHandler, TdsParserStateObject stateObj, Boolean& dataReady) at System.Data.SqlClient.SqlCommand.FinishExecuteReader(SqlDataReader ds, RunBehavior runBehavior, String resetOptionsString,
