oil derrick
Does any one no the correct bulb it take because the one i put in it is not powerful enough to make it bubble
bigdogjeff, Try 'Olsen’s:http://pictures.olsenstoy.com/ The bulb is #151-51, bayonet base, 14 volts, small, round clear, globe. With the year of manufacture of Lionel’s #455 Oil Derrick sometimes the liquid, inside the tube, doesn’t produce bubbles, as when newer. Good luck, Ralph
That lamp is a G-3, 1/2 (7/16-inch diameter), 14 volts, 200 milliamperes. You may find it more easily as a number 363 than by the Lionel number.
