Watching an episode of Simon Whistler’s Megaprojects YouTube channel on the Trans-Siberian Railroad, and up flashes a picture of a steam powered double headed train. OK, no big deal, right? Except these two steam locos are coupled up tender to tender.
I’m guessing wherever on the line they were running, there are no longer any facilities to turn steam locos, so the ran them, back to back like this so one would always be facing forward. But no trailing trucks, they look to be 2-10-0’s, running backwards. Actually, from the direction the steam is blowing, they might be pushing the train here, and what looks like the lead loco is the one going in reverse.
There is a picture of a backward running helper on horseshoe curve of the PRR. It is in Pennsy Power. I think it was a 2-10-0 also. Kind of strange there since there is a wye at top of the grade for that purpose.
2-10-0s were I think the most common Russian steam engine. The Bachmann 2-10-0 model is based on engines built in the US for the Russians during WW1. When the Bolshevik Revolution happened and Russia dropped out of the war, the engines still in the US were re-gauged and sold to US railroads.
Given the clarity and quality of the photo in question, my guess is it’s a very recent picture, most likely of some type of fantrip or tourist line operation.
2-10-0 were ideal pushers. The Santa Fe arrangement developed from this by adding a trailing truck to become the leading truck when used in reverse.
CPR built some experimental dedicated pushers in 0-6-6-0 arrangement with facing engines. When these did not work as well as hoped they were converted to 2-10-0 and operated for a long time at the Big Hill in Field and Rogers Pass from Revelstoke and Beaver.
At least one found its way onto the Kettle Valley Railroad which was basically an entire railroad built on punishing grades.
No doubt someone can weigh in on the advantages of the 2-10-0, particularly the small driver versions.
The small “Russian Decapods” were designed to spread their weight out over the largest possible wheelbase due to so much of Russia’s rail lines being built in marshy / swampy areas with light rail. They were nothing like the large 2-10-0s used by Pennsy or other railroads as pushers.
In the photo, it’s two engines back to back at one end of a train. My guess is the OP is correct, it’s running on a line without a turntable or wye at the end (probably a fantrip). The front engine appears to be working harder, so it could be the front engine is pulling the train one direction, and when they get where they’re going they use a run-around track to put the engines on the other end and use the other engine (now in the lead) to pull the train back?
