Okay prewar guys...Motor wheel/gear swap question.
Okay this is gonna be confusing to explain. I have a 262 which is a project for the layout. Just a runner, so i dont care if it’s correct. I always liked the look of the open spoke black drivers which were used on the late 260e and 255e. I have a late motor probably from a 262e or 249e. It has the dual reduction gears. Can i mount the 260e style open spoke drivers to this motor using the 260e/255e drive gears. The early style 262 gears dont mesh with the dual reduction gears, but the 255e used dual reduction gears on its motor so i assume the gears would work with the 249 motor i have. Okay if i havnt confused you i did good.
