Old Athearn Blue Box U-28 DCC with sound install?
Im wondering what is involved in installing a Tsunami sound decoder in an old Athearn U28? Why install DCC and sound in an old loco you say? Well this loco has alot of sentimental value as it was my very first “real” loco, ie non-train set loco. Its a rather handsome Burlington Northern unit that I purchased new in 1978 or 1979.I remember being very impressed with the fact it was equiped with flywheels, ran smooth and was weighted sooo much better than my Life Like locos.Im actually surprised its survived all this time with all the moves its been thru. I do have some experience installing sound decoders, but nothing in something this old.
It’s pretty easy, the main thing is you need to remove the motor and add a strip of electrical tape to isolate the motor from the chassis. I can’t think of the name right now but I know one of the Kalmbach “How To” books on DCC uses an Athearn blue box engine as an example, showing you step by step how to install the decoder.
Digitrax makes a “DHAT” harness that is designed for converting an Athearn engine to DCC. (Even though it says it’s a “no solder” method, I’d probably still solder the connections anyway.) I’ve used it on a couple of F7’s and it’s worked fine.
Stix, thanks for the info.
Before you fry a few decoders, why don’t you find out the stall current first?
David B
Or just look at the instructions and duplicate the DHAT harness yourself for free. You just have to solder the grey to the bottom motor clip, clip off the tab that sticks out to contact the frame, put a layer of tape in the bottom just in case, solder the orange to the top clip, the red to the tabs on the trucks, annd drill and tap a hole for a brass screw in the frame for the black wire. Cut off most of the clips on the trucks to make room for the speaker and enclosure. For a basic motor decoder in AThearn this should take a few minutes to do, really. A little more to fit a speaker and enclosure, which is the hardest part of the install. The only difference with the DHAT harness is the black wire clips to the headlight bracket instead of a screw in the frame, but this is highly unreliable as the headlight clip is just riveted to the frame is is often loose.
ANd yes, check curent draw, if it’s the black motor forget it, it will draw too much power and will need to be remotored. If it’s the gold color motor, it will probably be ok, but test. 12 volts DC, and grab the flywheels to hold the motor from turning. The current must be below the decoder’s limit or it will fry.
Thanks guys for the info/advice. I will check stall amps, motor color etc. Doesnt sound too tough.
Opened up the loco, good news, motor is gold and stall amps are under 1 amp. Found an outstanding how to vid on Youtube and will pickup the wiring harness. I think I will go with a motor only decoder,probably a Digitrax 123
When I rewire or remotor an Athearn, I solder wire directly to the brass rivets on the trucks (remove the sideframes first so you don’t melt them). Use 22 or 24 gauge wire. Pre-tin the wires and put a little flux on the rivets.
I agree with Randy in that the hardest part of this is going to be the speaker(s). Have you already decided on type and location for it(them)? An Athearn U28 is one loco not in my stable so I can’t pull one out and make suggestions. I could only guess.
