Hello all,
This is my official plea for “HELP”![8)]
My 10-year-old son was given an old Bachmann R/C Big Hauler (love at first sight). It must be an original with plastic everything (even wheels), but aside from the dust it is in really good shape. But I have no idea what I am looking at, never ever having worked G-scale before…! (Although it is a pretty nice looking train!) I’ve never even worked with R/C…
It is marked as a 49mhz R/C unit, but did not come with a R/C transmitter. With fresh batteries (6-D) it runs fine - light, sound - and it is not set up for smoke…
These are my three (for now…[%-)]) questions. (Any and all help would be appreciated…)
Inside the front smoke chamber plate, there is a place for an on/off switch, but no switch. What is this switch for? Is it for turning on/off the RC? (The on/off switch on the back of the cab makes it run from the batteries.)
There is a full circuit board inside the steam chamber; if it isn’t for R/C, what is it for? I see the batteries, motor, and light are hooked to it, and it probably controls the sound, but does it control the R/C also? (As I said, it is a full board so it must be doing more than making a ‘chuf’ sound…)
Sometimes smoke, but best guess on that one is a replacement smokebox front.
Sound board was often in the smokebox, radio boards on main chassis.
no.
Problem is, there were variations, and the last ones, done under contract, were track-powered units with battery chassis. Sound in the tender and all.
I have seen all sorts of wiring variations, placement changes in ones I have SCRAPPED for parts.
There are NO PARTS at Bachmann for these, so anything you find will be in someone’s junk-box.
I am trying to think if I’ve ever seen one with smoke…probably, but don’t recall. Would absolutely kill the batteries.
I’ve got one, it’s quite old. I know I’ve had it from at least 1990, probably earlier. I don’t recall if I ever used the smoke unit, but I seem to recall seeing it and not being overly impressed. I think the smoke should come out in chuffs, and this one simply came out like smoke out of a chimmney.
Meanwhile, I’ve got a similiar question. Can you rebuild these? I seem to recall somebody one the net was selling parts, anyone know the URL for that site? Mine is r/c and while I have the transmitter, it no longer works. The engine doesn’t run that well either, starting and stopping in fits and spurts.
Still, I like the blue and green color scheme, and would like to return this one to operation. Is there any other option beside picking up a new one?
