old fashioned!
I recently acquired a Starr-tec Hogger 100 mw with hand held remote to put on my old fashioned block layout. I need wiring diagrams, etc.
Someone suggested Sheldon (Atlantic Central) might be of help. Please Sir!
I’m certainly no wiring wizard, but for my own DC-powered layout, I did include blocks, mainly on double tracks, where one train might be parked while another passes by on the adjacent track.
To create such “blocks”, I simply add non-conductive rail joiners at each end of each block, then add a double-pole/centre-off switch to the fascia, connected by under-layout wires to the “live” single-track at either end of the double track.
There are only two powered wires feeding the entire layout, while the fascia switches determine which one of the double tracks will be used.
As a sole operator, I often use multiple locos on train, due to a number of grades, but only ever run one train at a time.
If you’re planning on running multiple trains at the same time, Sheldon can probably give you much more info on how to accomplish that, but it’s not something I’ve ever required.
I’m unfamiliar with your… ah… hogger, is it? But I do have my layout blocked out in ten (maybe more) DC blocks. I had a lot of help from, I think it was Mel, who provided a very detailed diagram from a book. It’s in one of my old posts. I could find it, but I’m not sure it’s anything you need if you’re trying to wire a particular item.
-Matt
[#welcome] to the Model Railroader magazine discussion forums. We are very glad that you have found us. Your first few posts will be delayed by the Kalmbach Media moderators, but that ends soon enough, usually after just a few posts. Please stick around through the delay and become a permanent part of the discussions.
Your Star-Tek Hogger is just a DC power pack (with walkaround and memory). If you make an oval of track and hook up two wires, the trains will run.
With DC, anything beyond that requires knowledge and skill. There are many books on how to wire a DC layout. All will apply to the Hogger.
-Kevin
Well, I really need a lot more info to offer any help. And I need some idea of your own electrical/DC control knowledge level/experiance.
As for the Hogger - seen them, never used or owned one.
Sheldon
Found this on Google Images:
Plus this text:
Walkaround unit shown. Not original coiled tether, but simple CAT5(?) cable. Has 1-1/2" hookup. Could use change to less prominent crimp style. 100 MegaWatt unit, Low power and high power switch for DC output, plus AC accessory output. At midrange (white line) on the throttle, it pumps out 6.5 (hi power) and 5.25 (low power) volts respectively.
Hope this helps.
A hundred megawatts! Now that’s impressive power. Since there are 746-odd watts to a horsepower, you could even with long feeders pull substantial consists up substantial grades.
In 1:1 scale.
Yeah 100 big M-watts, i gotta get one of those! Do they come in a Tech II flavour? [(-D]
I can see a club dispatcher now…
“Aye Cletus… over.”
“What you be wantin Zeke, over.”
“Ya know that six-eight wheeler is rated for 4 cars over the hill, right? over.”
“Yeah… over.”
“Ya got 15! Out!”
PMR
