Hi all.
I had an HO layout back in my teens, but have been away from the hobby since the mid 70’s and have a lot of catching up to do, now that my son has expressed an interest in railroading and model railroading.
I have the benchwork about half finished for a small (4’ x 8’) layout with specific results in mind. The mainline is a folded dogbone on two levels, with a mine/yard area inside the loop on the upper level and a town/yard area on the lower level inside the twin 180 degrees curve section that makes up the “fold” between the upper and lower loops, which are super-imposed on the other (right) end of the layout.
Both loops are set up to be reversing, and there’s a few other goodies in there that shouldn’t affect answers to the questions I have. The period I’m looking for is 1880 thru 1900, and the general objective is to model a locally famous (in southwest Colorado, my favorite backpacking place but about 1400 miles from home) narrow-gauge railroad called the Silverton Railroad, also known as the Rainbow Route.
I’m not going to use narrow gauge track, it’s already hard enough to find motive power and rolling stock for standard gauge. With the lower town being built modularly and the upper mine a popular tourist destination, I plan to be able to swap the lower town in and out to accomodate both my infrequently satisfied love for the area and period, along with my son’s preference for modern diesel locomotives.
That should outline the objectives well enough to ask the questions I’ve run into.
- Can I get away with a 5% grade? The period consists usually ran no more than engine/tender, a couple of shorty boxcars or coal cars or combo/passenger cars and a caboose. I can run as many modern diesels as necessary in tandem to get my son’s consists up the grade, with the proviso that the mainline uses minimum 18" and larger radius curves. The upper and lower yards use 15 inch radius curves, and the “snaky pilot overhangs” are both expe
