Someone from model railroad forum suggest i come here to ask my qustion. They said i could use # 4 wood screws. i want to use philp flathead screws or should i use nails instead and what size nails should i use. Gary
Gary, I used #4x3/4 pan head Phillips going through foam road bed into plywood. They work well.
wyomingscout
Definately screws. Brads, tacks etc. tend to work themselves loose over time on sectional track, especially if the track is not ballasted.
Becky
I also use number-4 pan-head Phillips screws, but 1/2-inch rather than 3/4, which would come out the bottom of the 1/2-inch (actually 15/32) plywood that I use. I pre-drill the holes to 3/32-inch with a Yankee drill dedicated to that task.
Screws for sure. Nails if pounded down can draw the rail out of alignment. Also hard to remove without damaging the track.
I don’t mean to go off topic, but I thought I was the only person who still used a Yankee drill.
Karl
I favor #6 Trim Head Square Drive screws. They won’t strip when you have to make adjustments, and actually have a track bolt appearance.
Every track screw on my 6 x 12 O-27 layout was put in with a genuine Yankee screwdriver. I also own & use a nearly identical Sears Craftsman unit. Real time savers, and very well constructed & durable.
Rob
I use plastic cable zip ties. I drill one hole beside the tie strip and another hole in the tie or on opposite side of tie. Then run the zip tie up from under the layout over or throught the tie and back down under the layout, then zip it in place. I read about this is a back issuse of either CTT or Model Railroader, for quiet running trains. Trains do run quieter without running screws through the cork roadbed and into the plywood.
Cork? Roadbed? Real men don’t eat quiche, and they screw their track right onto the plywood. If the noise is too loud, blow the whistle to drown it out…![]()
You tell them Bob
I thought you were supposed to screw them into the hardwood floor in the apartment. [;)]
Northwoods Flyer
Only if your magna-traction is too wimpy to handle running on the drywall! lol
LOL!
I’ve got a yankee push drill that I treasure. Got it for a quarter at a yard sale. I tried to find one for my son. Not made any more.
Ahhh, now I see my problem. I only run PreWar American Flyer. Who ever heard of Magna-traction. We Flyer folks have learned to do things with rubber bands most folks have never heard of.
Northwoods Flyer
I also use cable ties. I install mine a bit different than Smokymtguy though. I drill a hole through the plywood and roadbed beneath the hole in the tie and feed a cable tie through it. Then I use a second cable tie to cinch it in place under the table. I’ve also used this method to secure street lights and an animated billboard (that wanted to “walk” all over the place when running).
J White
Hi all,just a thought on quiet running from a newbie.New layout presently under constructon,L shape 16’ X 12’.I found that using sill seal under the track eliminates the high pitch rail noise on lionel 3 rail track.I purchase it at the local building supply store for about $5.00 for a fifty foot roll.It can be cut to half it’s width to create 100 feet of sound proofing material.It can also be painted and has it’s own pebble like texture.
That sounds interresting, I’ve been looking for an inexpensive roadbed material for my small S-gauge Flyer oval. How wide does it come? And is it easy to cut/bevel?
Becky
This product comes rolled up, 5 1/2" wide, about 1/8" thick and can easily be cut with a utility knife.It’s intended to be used as a seal against drafts in new construction.It would be placed between the floor and the bottom plate on the outside walls when framing a new home.It looks a lot like foam packing material.The pebble looking texture is just what this particular product reminds me of.I am not quite to the track laying stage yet to know what method I will use to adhere this product to my subroadbed.I have done a mock-up test and was impressed by how effective just one thin layer of this product quieted everything down.I would ask for it in the building materials section at a Lowes,Home Depot or other supply outlet.It’s refered to as" sill seal " and is probably made by several different manufactures.Let me know how this works for you,Shoal Creek RR.
