Olympia Logging Series: Part 9 - laying track
Great segment on track laying David and nice demonstration on connecting feeder wires to the bottom of the rails. Sweet.
Uh, David, in the video you still had the rail joiners between the track on the sector plate and the track to the turnout when you glued the track down. How did you get them off without upsetting the alignment?
Another very informative video segment. You guys are doing great with MR Video Plus.
One thing though… at 6:41 in this video, a ‘Talent Error’ graphic comes up chastising David about using the term ‘throw bar’. Unfortunately, there is a graphics error within it! It should read: ‘… the rod is much TOO heavy …’
If you’re going to call David out, you’d better be ‘golden’ yourself! :slight_smile:
Good job, nonetheless, guys!
What? No “out take”? One of the primary reasons I’m watching! If there were no screw-ups or verbal gaffes, go find one of Cody’s and stick it in here…
David, same question as Dale I think that is a very important piece of information.
Hi David so how do u get power to the sector plate for the locos
Great info. One thing, what is the largest gap size for an HO scale layout?
Excellent video David! Question… the feeder wire to power the frog, how is it fed into the main bus lines to receive power? Thanks!
