On the topic of Digitrax batteries
Has anyoen tried something liek this?
https://www.amazon.com/Luniquz-Creative-Lithium-Batteries-Rechargealbe/dp/B00WIB8HLI
DOuble the capacity of the Imedion low-self discharge 9.6V rechargeables. Plus the way these operate (since LiIon cells are 3.7V each) is that they have a boost converter built in which produces a constant 9V at the terminals until the batteries are too far discharged, at which point it shuts off completely. These sort of things are not suitable to short high current bursts but the DT40x throttles are a relatively low current steady draw rather than bursty, exactly what these things are made for. My only question is, do they fit? There are some brands of rechargeables that simpyl will not fit in the batter compartment.
They look pricy, but the low self discharge Imedion 9.6V oens are almost $13 each, for for $4 more you don’t need a special charger AND they should last a lot longer - both per charge and in the number of charge cycles they can handle.
I’ve been using the rechargeable EBL 600ma Lithium batteries for about a year in my great grand kids toys and they have held up very good.
I bought a four pack with a charger off eBay for about $20. I haven’t used them in any model railroad stuff because I don’t have a requirement for 9 volts. They recharge quickly and seem to last as long as a standard Alkaline battery. The system works so good that the kids (4 to 11) do their own thing with charging and replacing their batteries.
Mel
My Model Railroad
Mel,
Are these ‘thicker’ than normal 9v batteries? Could you take a micrometer to them and post the results? I just Googled them and like you mentioned - four 600 ma cells and a charger for under $20!
Jim
Can you recharge a lion battery (like those being discussed) in a charger designed for ni-mh batteries, I.e. PowerEx batteries and their mh-c40f charger?
No, the charging protocols are not the same.
CG
I had to go through the toys to find one. They measure 1.018" wide X .633" thick X 1.755" long not counting the terminals. I looked up when I bought them and it was October last year. They seem to be holding their own, the kids are hard on batteries.
I have two boxes on a hallway shelf marked Good and Bad. If the kids have problems with batteries they put them in the bad box. I run them through my battery anilizer and when they don’t hold to atleast 80% I put them in the good box. I have several multiple chargers on the hallway shelf and the kids do their own thing with AA, AAA and the 9 volt batteries. When I checked the bad box this morning the only batteries in it were older AA batteries.
Edit:
I checked the voltage of the battery I measured and I don’t know when the kids swapped batteries but I was surprised that the static voltage was 10.1 volts. (Fluke 179)
Absolutely not. And if those inexpensive Li-ion batteries (and $20 for 4 including the charger is definitely inexpensive) don’t have full protection built into the battery, it is very possible for the wrong type of charger to cause the battery to catch on fire. Li-ion batteries are great when it comes to power density and low self discharge, but they do need protection circuitry to cut off output or charging input if the temperature gets too high, and in a multi-cell pack they need circuitry to keep the cells balanced when recharging.
Thnx, that’s good to know about li-on battery types in general. Makes you have to consider if you would ever want to put a li-on battery (any brand) on a charger and walk away overnight. Or am I just being too over cautious? This doesn’t happen with ni-mh, does it?
The EBL 9 volt 600ma batteries do not say they are protected but because of the low capacity I wasn’t concerned. I use the high capacity 4 volt cells but I do not buy any that are not protected. I have several 5000 and 6000 mAh batteries in my goodies and they really pack a wallop.
The guys that use the electronic smoking devices have to be very careful, the heat coils in them can draw up to 25 amps from the 5000 mAh and up cells. Several of those Dingys have really hurt themselves, batteries exploding in heir pockets.
Mel
My Model Railroad
Ni-mh batteries aren’t designed to be left on the charger all the time either. If you do, you will destroy the battery’s capacity. Once charging stops, they should be taken off, not left on perpetual trickle charge, which is what most chargers do.
Li-ion chargers that are properly designed will cut off once the battery is charged. Leaving them on the charger probably has long term effects even if the charger does not cut off, but that’s not what makes them catch fire. What catastrophically damages a Li-ion battery is charging at the wrong rate. There are two points in the charge curve, initially they run at a constant current - you feed back X amps into the battery without regard for the voltage - the voltage will be low and gradually rise. Once it rises to a particular level, the charging needs to switch to constant voltage mode, where the voltage remains the same but the current gradually drops as the battery is fully charged. That’s why you can charge them with a lab power supply - any decent one will have a constant current and constant voltage setting
https://www.youtube.com/watch?v=jNmlxBXEqW0
Randy is correct about NiMH and Lithium batteries. For those who are using Lithium batteries there is a low cost charger board for charging them. The TP4056 can be programmed by changing a SMT resistor (very small chip resistor). The TP4056 comes programmed for one amp but can be changed as low as 20ma by swapping out one resistor. I use the TP4056 for 6000 mAh high capacity cells as well as 600 mAh AA size using a 4K chip resistor (4k = 300 ma charge).
I use a lot of 3032 Coin Cells and change out the resistor to 82K, that sets the charge current to 20ma for a 40 mAh 3032 Coin Cell.
The TP4056 isn’t much bigger than a postage stamp but handles 1 amp charging current.
http://www.ebay.com/sch/i.html?_from=R40&_trksid=p2060353.m570.l1313.TR12.TRC2.A0.H0.Xtp4056.TRS0&_nkw=tp4056&_sacat=0
Mel
Mel,
Thanks for the measurements. They are identical to my ULTRALiFE & IMEDION batteries. I have ordered a set of 4 with charger
Jim
Let us know how they work out. They should run a LOT longer than any Ni-mh battery, for the simple reason that Li-ion cells are nominally 3.7V each so you can;lt get either the 8.4 or 9.6V you get from nicad or ni-mh (1.2v each) cells. Thus those 9V Li-ion batteries incorporate a boost converter circuit to generate 9V. The benefit here is that the converter can get 9V out of the cells well down on the discharge curve. With your typical 9.6V Ni-mh battery, as it gets used up, the voltage drops. As we know, the Digitrax throttles are somewhat sensative to voltage, and will cut out or at least start acting erractic long before the battery is totally discharged. The boost converter on these Li-ion batteries will keep the voltage above the Digitrax cutoff through much more of the battery capacity. The cutoff will probably be swift and sudden though - once the cell voltage drops too low to properly power the boost converter, they tend to just shut off and produce no output. This could be an advantage - there would be no wondering if it’s the battery or something else, as at our club when people are swapping out batteries after only an hour or so thinking the battery is at fault when it’s not. If the throttle shuts off, there will be no question it’s time to swap the battery.
A mater of interest I use a 3.7 volt 6000 mAh Lithium battery for bench work and general testing. They are 4.2 volts static after charging and will normally power most 5 volt circuits for testing or experimenting. It’s much easier than toting around a power supply for low current projects. I’ve had one on my bench for over a week running different projects and it still measures 3.96 volts. Slick for working on LED lighting crcuits.
Mel
My Model Railroad
Bakersfield, California
Actually, according to the reviews, they use two cells in series, do not incorporate a boost converter, and hence will only to charge to about 8.5 volts.
I’m back. I ran two of the 11 month old EBL 600ma Lithium batteries through their charger and was surprised again, the static voltage right out of the charger is 11.1 volts. An hour out the charger the voltage on both dropped to 10.2 volts.
In the 11 months that my grandchildren have been beating them up the high voltage hasn’t damaged any of their toys but I’d beware of using them in expensive equipment.
Mel
My Model Railroad
No load voltage will be higher than with a load. I don’t think there is any danger using these - very few circuits actually run on 9V, most are 5V anyway, so the first thing after the battery connector (if they haven’t forgotten) is a protection diode and then a voltage regulator.
That’s kind of disappointing they don;t use a boost converter, that 8.4V won;t hold up long under load, and just two cells will net only 7.4V, not enough for many 9V powered electronics. There must be two different ones though, if Mel’s charge up to 11.1V - that’s 3x 3.7V cells, but fully charged no load they should be 4.2V per cell so an initial 12.6V which would quickly drop.
One of the Youtube electronics bloggers surely has opened one of these up to see what’s inside, I’ll find that.
OK - The EBL-855 charger and four 600 mHa batteries have arrived and are in the charger. Per the user manual, the blue LED will become darker and will charge the battery at a 20 ma until the MCU protection board kicks in.
It appears there is no boost converter in these batteries. I am going to take them to the club Wednesday and put them in some DT400R and DT402D throttles.
Well, it’s about 2 PM on Sunday afternoon. I checked the battery charger before I left for church and the blue LED’s were all dark. I just checked each of the batteries and the are charged to between 8.44 and 8.51 volts. I pulled two of them and inserted them in a DT400R and a DT402D throttle. I checked the voltage ‘under load’ and they did not seem to drop(I put a 8.44v battery in the DT400R and a 8.51v battery in a DT402R). I have not left them plugged into the LocoNet as I want only the throttles to ‘drain’ them. I did plug them momentarily into the system just to assign them each a loco. I will spin the encoder knobs every once in a while to simulate commands be sent over the ‘wire’…
Jim
Drove down to the club this morning - I put a charged battery in a DT400R & a DT402D. I let two trains run, changing the throttle speed every 10-15 minutes.
After 3 hours, I measured the batteries while they were still under load(in the throttle). The battery in the DT400R was 8.4v and the battery in the DT402D was at 8.2v. This is not really any better than the PowerEx or Imedion batteries. I think I am going to look around for some with the ‘Boost’ technology …
Jim
Wait though, after 3 hours they were effectively where they started, at least the one in the DT400R. The DT402D though, that was pretty signigificant drop if it started at 8.51. These batteries are supposedly nearly 3x the capacity of the Imedion at 600mAH vs what, 230mAH. I’ve been told by people who know battery design far better than I do that 600maH is a reasonable number for a Li-ion in a 9V size. I’ve seen som others advertising 800maH and higher - thoise a certainly scams as the chemistry vs size would not allow that capacity in that size container. But it really sounds like these 600maH ones are also falsely rated if they don’t hold up
Kind of disappointed, I thought maybe there was finally a way around my idea of just fitting my own boost converter circuit to my throttles (voiding the warranty). Actually I wanted to try a boost converter and power it from a pair of AA batteries instead of a 9V - 2 AA will fit in the same space in the battery compartment, and AA’s can be had with some insane capacities. Even AAA’s will have a greater capacity than a 230-250 mAH 9V. The real trick is to examine the circuit - if all power in the throttle is derived from a 5V regulator, it would be possible to bypass the regulator and design a boost converter to put out 5V. A 5.3V Zener could provide overvoltage protection.
Maybe there are some better Li-ion “9V” options.
