Onboard Camera Test #2
Second camera test of my onboard camera after making a new bracket for the camera car. On this test, I decided to try pacing an Amtrak passenger train around the layout, which allows for a view in the windows at the interiors of the cars that I hand painted as well as the window shades and passengers.
Kevin
Great video, thanks for sharing. Just curious, are you modeling a prototype Amtrak train? If so, which one?
Best quality video I’ve seen from on train camera. Did you use wifi or record to camera?
That is a great video. What I find to be even more impressive than the video is the apparent size of the layout. Can you give us the approximate dimensions of the layout? I really like the different views of the Amtrak train, first behind it, then beside it, then in front of it. Did you edit the video to splice in the various views?
That’s a great test shot run. The video quality is very clear. The action looks more real the slower you go with it. The higher speed action sure shows how smooth your track work is though!
It must be nice to have a layout big enough to run a passenger train that long on it and look good doing so! Dan
It is nice and clear. It looks like the camera Ed (gmpullman) has. Impressive Amtrak train!
I only watched about 3 min. worth, which was about 3 or 4 times around the same loop.
I’d never last the complete 26 min. [(-D] But that’s just me.
Mike.
I agree on both counts, Mike. I’m not even sure the Contour Roam I have is available anymore. Maybe there are better ones out there?
Kevin’s is a Sony HDR AS-20. Their video gear has always been top-notch!
The results are very good though [Y] Kevin.
Regards, Ed
Nice video! You passenger train looks great, but I wish we could have gotten a lower angle! I realize that is probably near impossible for the op to change, (maybe a depressed center flat car…) but I would make for a more realistic view and make it easier to see into those nice passenger cars!
Answers to some of the questions:
  1. In addition to the 2 SDP40Fs and the 11 Heritage fleet cars, I have 3 Amfleet II coaches, 1 Amfleet II Lounge, 2 Amfleet I Food Service cars, 6 Amfleet I coaches, 5 MHC cars, 2 F40PHs, 2 P40s, and a third SDP40F on order (whenever Athearn decides to finally release the next run). On the east-west route shown on the video, I’m modeling the Broadway Limited and (my version) of the Pennsylvanian extended to Chicago. On the route crossing at the tower is my ficticious Cleveland-Columbus route, which is where the Amfleet I cars are used for regional trains on that route between the staging yards. Train length is determined by consist cards that I made up with random numbers of bedrooms, coach seats, etc. to determine how many coaches, sleepers, etc. are needed per train. The Broadway and Pennsylvanian can run with up to 18 cars while the Cleveland-Columbus trains run with a food service car and one to three coaches.
  2. The camera records to memory card.
  3. The main layout is 17.5X12 feet (2 feet across). The leg outside of the oval is 12X1.5 feet. The leg inside the oval is 10X1.5 feet.
  4. The video was edited using Adobe Premiere Elements, doing two shots at once (except for the bloopers). I’d let the train overtake the camera car and then speed up to overtake the train or vice versa. The train catching up to the camera was crossing the locomotive and camera car over in front of the train, leaving plenty of room to stop in case of a derailment. :slight_smile:
Kevin
Can PS Elements invert video? If you think you’d like to see a view that is closer to the tracks, invert your camera, and then invert the recording.
Probly knot… but try putting the camera in the carrier upside down, and then inverting it in post production.
LION likes the track work. That is the first him saw. LIONS do not make such nice trackwork. But WTH… Lion models NYCT, you they they have ince trackwork?
ROARING
In several of the shots, the camera is upside down (flip mode turned on), especially evident in the shots of the train catching up to the camera on the same track.
Kevin
Kevin, can you tell me the dimensions for this camera? Thinking of HOn3.
Okay. I have never used a video cam, and never used Photo Shop, but I wondered if such a thing were possible. Thanks for sorting that out.
3 inches long, 1 inch wide, and just under 2 inches tall.
Kevin
Thanks!
Just for kicks here is a HO scale drawing of the Sony camera on a Bachmann Depressed Center Flatcar.
Mel
My Model Railroad
Bakersfield, California
