One of the last operating remnants of the North Shore Line.
CTA’s Yellow line from Howard to Skokie, I think this used to be called the “Skokie Swift” from the speeds of the line and if I read elsewhere correctly the line was used by trains to Milwaukee from Chicago.
https://www.youtube.com/watch?v=pVaEW1Pk234
Interesting video.
When was the catenary taken down?
Correct. The Skokie Valley Line was the newer, faster route through northern suburbs compared to the older Shore Line route.
The high-speed Electroliners used this route.
The rails were removed after the North Shore ceased operations in 1961. Rails and the catenary were reinstalled for the CTA’s Skokie Swift. Although, the CTA uses 3rd rail, it used overhead on the Yellow line until 2004.
That was a fun head-end ride video, one of the better ones I’ve seen!
On thing though, referring to the overhead catenary as an “aberration?”
If I was an overhead catenary I’d be highly insulted!
I didn’t realize CTA rapid transit lines had road crossings.
CTA retained the line for access to the Skokie Shops, still CTA’s principal shop complex. The rail and wire west of the shops to Dempster Street was intact in 1964, though CTA crews did work there to prep for the Skokie Swift, using ex-CNS&M line car 606 to do the work.
I recall Trains had an article on the Skokie Swift back in the '60s. Sure wish the ROW from Skokie north would have been retained.
Is not some of it actually in use because of a C&NW freight line relocation now used by UP?
If you look north from Dempster Street, you can see that the C&NW tracks were relocates slightly west to accomodate a Com Ed transmission line.
In response to the various notes on the North Shore Skokie Valley route:
(1) As prior notes mentioned the North Shore trackage between Dempster Street and Howard was acquired by CTA following the NSL abandonment and used for the Skokie Swift (now the CTA Yellow Line). The North Shore catenary between East Prairie and Dempster wasn’t removed after the NSL abandonment, and was used by the Skokie Swift until it was converted to 3rd rail (one of the other notes says this occurred around 2004, which seems about right).
(2) CNW had a freight line right next to the NSL Skokie Valley Route on the west from Oakton Street north to about Lake Cook Road. This was built around 1903 or so and predated the NSL line. It was part of a line that continued south from Oakton to a connection with the CNW Weber Line at Bryn Mawr Ave, in Chicago (Bryn Mawr Jct) . The combined lines then ran south through the Mayfair interlocking, continued south as what later became known as the Cragin line to the CNW freight yard at 40th Street (now Pulaski), which was CNW’s main Chicago area yard before the construction of Proviso Yard in the 1920’s. By the time of the NSL abandonment, the CNW line was in very poor condition, and would have required substantial and expensive reconstruction to remain in service.
(3) The NLS abandonment gave CNW a way to address this problem at minimal cost (it probably even made a tidy profit on it). What happened was this:
(i) CNW acquired the NSL line intact between Dempster Street and a connection with the CNW “New Line” Subdisivion near Lake Cook Road.
(ii) CNW built a connection just north of Dempster Street beween its existing line and the NSL southbound main. This became the “new” CNW line. The original CNW line was then abandoned, salvaged, and the underlying property sold to developers (there’s very little evidence today that i
Existing CTA lines with grade grossings are:
Purple Line (far north end)
Yellow Line (East Prairie to Dempster Street)
Brown Line (Rockwell to Kimball)
Pink Line (Kilbourn to 54th Avenue)
One additional factoid on CNW’s acquisition of the NSL ROW between Dempster Street and Lake Cook Road.
The NSL south of Lake Cook Road was in a joint corridor with Commonwealth Edison (former Northern Illinois Public Service Corp) utility lines. NSL actually had two right of way strips in this corridor (illustrated in the CERA “Route of the Electroliners” bulletin). The western ROW strip was the one that had tracks on it. The eastern ROW strip was between the utility strips, and was intended for an additional two tracks, which were never built. I’m not entirely sure of this, but I believe the CNW acquisition included both the formerly active NSL ROW strip and the never used NSL ROW strip between the Commonwealth Edison (ex-NIPSCO) utility strips, which CNW then turned around and sold to the utility (again, showing that the NSL deal was probably a really good deal for CNW).
For further info on the CNW-CNS&M Skokie line, see the environmental/historical report filed as part of UP’s abandonment / discontinuation petition in 2002:
https://dcms-external.s3.amazonaws.com/MPD/78432/85257CA7006C955B85256BB2005B1D17/205337.pdf
Falcon: I greatly appreciate the update and the detail. I definitely consider myself a fan of all three “Insull Interurbans,” and the two CERA North Shore books are still here with me in Israel.
I donated my Milwaukee Electric CERA book to the local American Consulate Library to conserve space in my tiny apartment, thinking I could still use it when needed, and it giving a good idea to Israelis as to how American cities grew with dependence on the streetcar in many cases. The librarian, an immigrant from S. Africa, disaccessed it and did not notify me, and I have no idea where it is. When I have the cash, I hope to purchise a new copy, as well as rejoining the CERA.
David, that’s the problem with donating a book to a library, or any library for that matter. If it sits on the shelf for the longest time with no apparant interest they’re going to de-acession it to clear the space. And as you’ve unfortunately found out they’re not likely to contact the donor to see if he or she wants it back.
Next time, check your local friends and aquaintances to see if any of them are interested, if you didn’t do so already. At least you’ll know where it is.
A good source for railroad books like this which are long out of print is the Illinois Railway Museum used bookstore They seem to get a lot of old books from estates which the heirs simply want to dispose of. I got a copy of the CERA TMER&L book there a few years ago, at a very reasonable price. There’s always new stuff coming in as my generation gradually dies off and the heirs get rid of their unwanted railroad libraries.
Unfortunately, the store does not appear to have a website presence (probably because the people who run it are even more computer illiterate than I am, if that’s possible). I’ve left a note at the museum for contact information (I’m a longtime IRM member) and I’ll pass the response on when I get it.
Thanks. I was also an IRM member and hope to rejoin sometime in the future.
It’s a great railroad museum, and transit is well represented.
The North Shore Line abandoned operations in January, 1963. CTA purchased the line shortly afterwards and inaugurated “Skokie Swift” rapid transit service in April, 1964. The tracks and overhead were never removed.
And in the interem period, the CTA coninued to use the part of the line needed to reach its major shops.
