My Zephyr is giving me the open circuit “d n d” error message in programming mode - can someone help me understand how a single piece of wired track - I’ve tried a piece of flextrack with soldered connections and then even an old Tyco-style terminal track, too - can have an open circuit?
Assuming the wires are attached at the terminals, could it be that you need a resistor for that decoder?
The Zephyr instructions certainly don’t call for a resistor - it’s basically plug ‘n’ play…?
Two suggestions:
Make sure you have your programming track connected to the correct programming track terminals. It’s amazing how often the obvious eludes us (speaking from experience here…)
You seem to have concentrated on the track to Zephyr connections, but the open circuit may lie elsewhere. Are the programming track and wheels clean? Are the pickups in good working order? Is the decoder wired properly and known to be in working order?
1- Could be the contact between the decoder and the programming track is not good.
2- If it is a Lenz decoder a resistor across the rail may be required.
3- To read some sound decoders requires more power than the Zephyr provide. They program fine however.
How would it know there was an open circuit. maybe there’s just no loco on the tracks yet.
Don’t forget the PGM A and PGM B program track connections are NOT adjacent to one another on the connector, there’s a ground connection in between.
I have the same problem with my Zephyr on some types of decoders. My fix was to attach a 1k resistor across the rails with alligator clips. That solved the problem.
