Open up a Marx Yard Tower?
OK, I just bought a Marx Yard tower…and I want to get inside to check the light and repair the red plastic window scrim. Probably should re-wire while I’m in there too.
How do you open one of these things up??? Do I need to bend out the tabs and take the whole building off?
Thanks,
Kurt
The roof slides off.
Got it! Thanks. Not an easy task. The roof tabs were a bit bent up holding it in place.
Good thing I check and clean everything used I buy. This has a chunk of wood next to the light bulb…probably holding the acetate in place???
Kurt
