Operating Lionel Postwar 153 Block Signal
Leica wants to know if anyone knows how to wire the Lionel 153 Block Signal with red and green bulbs so it will switch from one color to the other and back using an isolated track as the switch on 027 layouts? The pressure sensitive 153 connector won’t work with a track where ballast has been used because the 027 track won’f flex sufficiently to trigger the switch. I want to use the block signals on spur lines and different combinations of the 3 posts have been tried without success. Comments and assistance will be most appreciated. Thank you.
Page 81 of the February 2007 Classic Toy Trains has a great diagram & explanation to do exactly this.
Use the insulated section to trigger a ~12v DC SPDT relay through a bridge rectifier. Center post of the 153 to acc. power, ground to common(center) contact of relay, NO to one bulb/post, NC to other bulb/post on 153. Vary the length of the insulated section to get the effect you want.
Rob
Here’s a link to a similar topic: http://www.trains.com/TRC/CS/forums/998337/ShowPost.aspx
I just started installing relay/rectifier combos on my layout. To save money, I purchased my parts from Mouser ( www.mouser.com ):
893-833H1CS12VDC SPDT Relay, 10A, 12VDC ($1.00 each)
821-GBU404 Bridge rectifier, 4A, 400PIV (.72 each)
Although these parts are relatively inexpensive, they require soldering wires to them (or soldering the rectifier’s DC terminals directly to the relay’s coil terminals). I wouldn’t use them if I didn’t have previous experience with soldering.
Rob, you’re right, the diagram in the Feb. issue is a good reference. I noted the diagram shows the 153 center terminal (neutral) and relay common terminal (hot), but I think your way would work, too. IIRC, switching the hot side is the conventional way to do it.
Leica, Welcome to the forum! Hopefully the info you’ll find here is better than what I’m going to give you regarding the 153 signal and an isolated rail.
Your 153 will work with an insulated rail section , but it will require a relay (12VAC) in the circuit to make it work. These relays can be purchased from (in no particular order): Burns manufacturing (see ad in CTT), scotts odds and ends (also in CTT), and my personal favorite Fuctional Devices (These relays, #RIBU1C, are found in heating and air supply houses). I’m going to try to explain the circuit, and hopefully this diagram will help as well:
I apologize for the poor image, but it was spur of the moment. Basicly, the relay’s coil will attach to the center rail (or its post on the transforme), and the insulated rail. To the 153 signal, two wires will come off the relay, one from the normally open contact and one from the normally closed. The final wire will come from the non insulated outer rail. Unfortunately, I don’t have a 153 in front of me, so I don’t know which of the three thumbscrews attaches to which wire.
Here’s how to find that out: With no train on the rails, and the transformer powered up, (with the throttle turned up) take the lead from the noninsulated
Forgot abut this, click on the image to enlarge it; it’s not a very good drawing to begin with, but on my monitor, I can make it out after I enlarge it.
J White
Thank you so very much for your time and consideration of my query about operating the Lionel 153 block signal with an insulated rail. It is most appreciated. Leica
Since I’m a “electrical dunce”, I found it easier to just use a $27. Lionel IR controller. You can also buy Z-Signal stuff with built-in IR detectors. Joe
I use 2 insulated sections. 1 for the green light and 1 for the red. The outside wires on the signal are those. The middle is the power, connected to your acc. post on the transformer. This is a simple way to activate the signal.
There is a way to do it that is simpler than using a relay:
The signal has three terminals, one connected to the red lamp, one to the green, and a common connected to both red and green. Connect the common to the isolated control rail. Connect the green lamp to the other outside rails. Connect the red lamp to the power supply that you will be using, whether the center rail of the track or an accessory voltage. The accessory voltage may be AC or DC, whichever is more convenient, and does not need to be in phase with the track voltage if AC. It should be a suitable voltage for the signal and should share a return with the outside rails of the track.
Finally, connect another incandescent lamp or lamps, with the same voltage rating as the signal, in parallel with the red signal lamp, that is, between the signal power supply and the control rail. This lamp or these lamps should be selected to draw somewhat more current than the red signal lamp. You can hide them under the layout; or you can use the lights of some other lighted accessory. For example, you could have a 395 floodlight tower somewhere on the layout, perhaps far from the signal, that will light up when the signal switches to red.
It works this way: When the train is not present, the red and green signal lamps are in series and powered by the signal supply voltage source. However, the red does not light noticeably because the other lamps in parallel with it reduce its voltage to almost nothing. Most of the voltage goes to the green lamp, which lights brightly. When the train comes along, it shorts out the green lamp, which is connected between the control rail and the outside rail, and applies the full voltage to the red signal lamp as well as to the other lamps in parallel with it, lighting them brightly.
I’ve put some numbers to it. When you use a single extra lamp of the same kind as in the signal, the green lamp should be about 82 times
