I’ve been in this hobby for 37 years. I’ve done HO, N, even a bit of Fn3. I’ve ripped both steamers and diesels to shreds and reassembled them, mostly successfully. I’ve torn the same 4’ by 6.5’ sheet of plywood down a dozen times and rebuilt it as a new ‘layout’. I’ve been to train shows, i’ve rail fanned, i’ve been in model railroad clubs.
Yet, I’ve never done a lick of scenery. I’ve never built a layout building, carved a plaster rock, or even planted a ruddy little model tree. I have never taken a layout past the lumber/track/wires stage. I am a complete neophyte when it comes to un-uglying a scene.
So my question is this: now that I have the time, resources, and interest to take a layout past its hideous early stages, what comes first? Do I get my operations nailed down perfectly? Do I dabble with the scenery beforehand? Do I get a backdrop in place to make the Growlery look less like the back aisle at Home Depot?
I realize this is a ‘do whatever you want’ question. I’m curious how other more experienced modellers have proceeded. Thank you all for your guidance!
I would get the trackwork done first. Here’s the thing, and it happens to me. If you try for perfection with the trackwork, you might find yourself never finishing it. And if you have a lot of engines that even compounds the time. I love doing scenery! But if you do that first, it might get in the way of doing trackwork. One thing I would do before anything, is to get the room looking the way you want it. That would include the backdrop before the benchwork.
Only one time did I get to the scenery stage - and that didn’t get beyond a little plaster hillside. Otherwise I have never finished the track laying and wiring stage. For many reasons, the layout gets torn down before scenery. But to be honest, I’m mostly interested in running trains so I strive to do all the benchwork, tracklaying, and wiring before any scenery.
I have a rather larger area for my layouts, so was blessed with enough space to both work on track and do scenery without getting in the way of each other. Sounds like you won’t have that working in your favor. But my most recent expansion built on techniques I learned on the first part of the layout, most importantly how to build lightweight liftouts from extruded (pink or blue) foam, shaped and overcoated with Sculptamold.
What I did with my Cascade Extension was to build the benchwork, based on L-girder/cookie cutter but adapted to my needs, then build most of the scenery on it as a series of liftouts. http://cs.trains.com/mrr/f/88/t/219241.aspx?page=1
I didn’t have much funding for the track I needed at first, but I was able to lay a main for a nice long run and a terminal at the end, so it was operational and had roughed in scenery fast. When the Purchasing Dept could do so, additional track was procured, the sections removed where it could help with tracklaying and wiring, and then they were reinstalled. As things were finished up with track,the scenery got more detail once it was staying in place, more or less.
I have only very little space available for a layout - in fact, not more than 3 by 5ft. for an HO scale narrow gauge layout. Naturally, one can´t expect a lot of operation on a layout that small. Basically, it´s just on oval of track with a stub-end siding.
End of last year, I finished laying the track and the basic wiring was done, so I could run a train over the layout.
Nothing thrilling at all! The begiining of this year saw the start on scenery, which, at the end of January, looked like this:
Still not at all thrilling, the lack of scenery really made this layout into a dull thing anyone would lose interest in after a couple of minutes.
Fast forward - in those 6 months since the above picture, the layout has undergone quite a transformation!
It´s still the same old, rather boring “operation” but I do enjoy watching the train run through the scenery, making the layout a lttle more “thrilling”
The layout is far from being complete - a lot of details are still to be added, the biggest addition being the catenary.
I really enjoy this layout, despite its limitations in terms of operation. Scenery, at least to me, is equally important than operation, which by itself, would not sustain my interest much more without anything “nice” to look at.
In spite of the best “professional” advice to get your track down, wired, and tinkered with so operation is bulletproof first before even thinking of doing any scenery, I myself found it motivating to at least commence a couple of signature scenes that I was hoping would look nice, even as the track was still being laid elsewhere and before even basic experimental wiring had been installed. This included not only regular scenery creation but also my first efforts at bridge scratchbuilding, using static grass, and pouring (and sealing!) Magic Water.
What I would say is that it gave me enough of a rewarding foretaste of what the future might hold to give me the willpower to keep on with the boring parts.
Larry I couldn’t agree more. But OMG sometimes it seems so frustrating at times. Like most members, I have collected a good bit of engines of several brands, diesel, and steam. And on top of it all, I have a reverse loop. So all these engines having 0% derailments (or any other problems), in both directions, sometimes seems like an up hill battle. My operations would be running 2 or 3 engines at a time with their trains and if everything goes well, I switch them out daily. And after 10 or 11 engines run flawlessly and I feel comfortable that the track is in good shape, guess what? the 13th engine gives me some sort of problem. So its back to working on the track. And scenery is put on the back burner once again. Also to respond to another post, I have worked on scenery in certain spots while still working with the track. But the scenery is an areas in the back. I don’t have to work around it.
The best idea is to consider what kind of scenery you want beginning with the initial planning, and allow for it all through construction.
It is entirely possible to model a modern “wrong side of the tracks” urban-industrial area without ever shaping a hill, carving a mountain or planting a tree. Roads, sidewalks, parking areas paved and gravel, little islands full (or part-full) of stunted ground cover, the plainest of plain concrete structures…
It’s also possible to work on scenery (at a place where both surface and subterranean track has been op tested bulletproof) while only a few feet away there is subgrade awaiting roadbed, with track to follow.
Then, too, what is the relationship between the track and the scenery? If you have a shelf, all the layers of scenery beyond the right-of-way fence can be built before a single tie touches the roadbed in the foreground. On the other hand, if the rails run through the scenery instead of in front of it, they had better be laid, tested and thoroughly debugged before you roof over the tunnel or plant a forest along the fascia.
There is also the will of the owner. Linn Westcott once defined an operating model railroader as one who wanted his signals to operate correctly before embarking on scenery construction. Au contraire, the model railfan wants the train to pass through realistic terrain so people can enjoy the 1:1 scale activity in smaller size.
My vote? If the trackwork isn’t bulletproof, world-class scenery won’t be appreciated. Where the trackwork IS bulletproof, go for it.
Chuck (Modeling mountainous Central Japan in September, 1964)
People seem to find that troublesome. Fact of the matter is we’re forced to wear the hair shirt plenty enough in life. Without a little extra inspiration, lots of folks would otherwise fold their tents and go home. I’m with you Dave, scenery helps sustain you through all the boring stuff. You find a balance in many cases – or you just give up. There are those who think of the hobby in exclusive terms – all the people who don’t quite measure up in some way – may want to lose those sorts of folks. I don’t think our hobby can afford to lose anyone.
Then there is the idea of 100% or bulletproof track. If you can accomplish that, great. Then try to keep it that way. Maybe where you’re lucky enough to have 24/7/365 climate control. Otherwise, things change, wear out, and move. What was 100% yesterday might be 98% tomorrow. Then there’s new track. Yep, lay it carefully and skillfully. But it’s rare that it’s 100% first time, every time, with every bit of rolling stock running through it without a hitch. You do have to work at it to get it there as Larry notes, but these other factors mean it’ll only stay 100% with a lot of hard work and some test running that may not be so perfect.
Then you take all that, extend it to ~500 SF and put it in a basement in the Midwest and if you can keep it at about 98% that’s plenty good enough for me. After all, what reall RR was ever 100% derailment-free? It’s just not prototypical, some roads more than others.
Circumstances (mostly my own ill-advised life choices) have kept me from staying long enough in one home to put down serious roots. We all know that building a layout takes time, space, and not moving your silly self every few years because you hit on the landlord’s daughter again. Finally my family is in a long term space, somewhere the layout can be a permanent addition. Thus, I can finally go whole hog on this.
I turn 40 this year, providing a convenient excuse to blow money on trains. I’m not slow to take advantage.
Thanks to all for your input. Ulrich, who cares if it’s small? I love that setup!
When you said that you have been in the hobby 37 years and not got beyond the track on plywood stage, I picture some 77 year old who started in the hobby at age 40, not some 40 year old who who started in the hobby at age 3. [(-D]
By all means, then, start landscaping, detailing, and ballasting. [Y]
Well I may be in the minority, but my layout is almost finished as far as scenery. Mine is a modest 15x30’ layout with two yards and a dozen sidings in a dogbone shape. First off get the track to run well. Next do your basic hills and valleys (if you used a foam base this is easy, if not, not so much. Next do your basic ground cover, then I ballast and start to put detailed scenery in, like buildings roads, trees and bushes.
Well, Rrebell, I hope you don’t mind me picking your brain a bit. I too want to go the foam base route, but my scenery is heavily skewed towards rugged mountains. Any suggestions? Warnings? Headache pill recommendations?
I use foamboard for level surfaces but I found something easier and faster for hills and mountains. It’s the Woodland Scenics Shaper Sheets. go to their website and check them out.
Okay, I like that. Self-supporting hardshell. She doesn’t go into a lot of detail about combining it with the plaster cloth; I imagine that would expedite the seaming process.
Quality bench work then track and full wiring thorough testing and play time.
Then once thats done and trains run flawlessly scenery which is basicaly done where whenever and how you want to do it.
It is however a good idea to get any backscene up at benchwork construction time before track goes down as these tend to be big sheets of wood if using traditional construction methods and could damadge track and trains.
