What do you all think about the need to turn your engines? Though I realize that certain ops call for it.
I definatly don’t think I have the room for a wye, but becasue of the locale I don’t know that a turntable will fit the scene. I’m doing 1920’s logging and don’t model a large city that would have a servicing facility with turntable. I’ll probably have shays that can run in either direction, thats fine… But what about the other steamers that come and go? Should I just plan on having them run backwards also. Or another option could be to have a small scratchbuilt turntable just for turning… I’m kind of stuck on the idea nd could use some input.
in the steam era, quite a few engines ran backwards half their lives on short line railroads. even the class one mine jobs operated in reverse half the time. note the back up lights on tenders particularly on the IC and Burlington steamers that worked in southern Illinois.
Steam usually, though not always, got turned. Lead trucks were basically useless running backwards. This might be less important in a backwoods setting, though I think a small turntable of very crude makings might be a cool piece to have on a layout.
Diesels, not so much need there, though some companies had rules dictating which end of the loco went first, so for them, they needed turned. Norfork & Western comes to mind, as they dictated long hood first.
My coal-hauling private railway runs a motley collection of tank steamers that are never turned end-for-end, even though there are turntables available at both ends of the line. Most of the route climbs a four percent grade, and the front office has decreed that the firebox end of the boiler will always be downhill, to assure that there will be water over the crown sheet.
So, why the turntables? The one at the interchange yard belongs to the JNR, which DOES turn road steam end for end. The one at the colliery is used to turn cars which have to be unloaded from a specific side and arrive ‘wrong side to,’ and to turn single-ended brake vans to keep the markers pointed in the right direction. It also turns the business car so the observation platform will be at the rear.
Tank locos can operate in either direction at their maximum safe speed. If a tender-equipped steamer is to be backed for any distance, it is usually required to do so at restricted speed. That said, there were coal-originating branches without turntables all over Appalachia, and many a mallet backed from the branch junction to the mine or vice versa.
If the train goes from point A to point B and then return to A, one will need two locomotive turning facilities, one at point A and one at point B, if the locomotive is to run forward in both directions.
If the train goes from point A to point A, and then reverses directions to return to point A as on some model railroads, only one turning facilitiy is needed.
Backwoods logging operations such as where gear locomotives were common, wouldn’t have locomotive turning facilities. I don’t know of any, but I’ll allow the possibility that someone did somewhere.
That’s why logging railroads sometimes favored locomotives with trailing trucks, not for carrying weight of a large firebox, but for guiding “pilot” trucks at the back. That is what differentiates logging Mikados from regular Mikados. The style of the trailing truck is different. (Normally, trailing trucks on locomotives are for carrying firebox weight rather than for guiding. You’ll note on SP’s cab-forward 4-8-8-2 locomotives that the leading truck is guiding in its design even though it is under the firebox.)
A rod locomotive which had frequent, long-distance backwards runs would have a headlight facing rearward and a tender, if any, that permitted good rearward visibility.
Your logging like really does not have much need for a turntable. Geared engines like Shay’s really run fine in either direction. ‘Rod’ engines can be a different story. Something like a 2-8-0 will track better in forward. That said, the Buffalo Creek & Gauley ran their ex-B&O 2-8-0’s without turning them. They factor is if they are going to be run at ‘main line speed’ - then pilot wheels are needed. Manny logging ‘rod’ engines had trailing wheels due to the need for lots of reverse running. Wye’s and Turntables can take up a lot of real estate. I have a turntable with a 3 stall roundhouse. It has a 3 track ‘lead’ and eats up about 7 ft of space. The good part is that it is on ‘L’ off of the main layout space!
With your Shay’s - make sure that right hand side with all the ‘action’ is out so the visitors can see it!
There are multiple examples of steam operations that did not have a method to turn the locomotive. The Buffalo Creek & Gauley (which made connections with a logging line) was mentioned above. I just viewed (the first time) the DVD “Narrow Gauge East of the Sierra” about the Southern Pacific narrow gauge in Nevada, and there was film of a run up the line with the 4-6-0 locomotive running backward (with tender and extra water car first) up the line for miles to pick up some cars. Although there was a turntable at the far end of the line, they ran backward to pick up some loads rather than put in the extra mileage to get to a turntable.
There are multiple other examples in my books on short-lines, and I would venture that the majority of logging lines used “out and back” operations without turning facilities most of the time. Notice the number of western logging lines that used 2-6-2T and 2-8-2T type locomotives where they operated equally well in either direction. Mechanically, it made little difference to the locomotive, although speed had to be a consideration for rod locomotives without trailing trucks in reverse. At the Cass, West Virginia example, it was generally more important to keep the locomotive headed UP the hill to keep water over the crown sheet on the grade than to turn the locomotive.
Locomotive servicing facilities are “neat” and exude the railroad feeling, so we tend to model more of them than an actual railroad would have supported. I model an HO could-have-been mining and logging short line around WWI. My new shelf layout does incorporate a (single) turntable that was transplanted from the earlier large layout, but trains have to run out-and-back. I position the locomotive so that it will be in “normal” boiler-first operation when it is pulling the loads. Empty hoppers go to the mine behind a tender-first locomotive, a
Thanks for all the great info guys. Thats good to know about the crown sheet and keeping water over it. Does the T at the end of 2-8-2T mean that it has a trailing truck? And if so I should just make sure I have those kind of steamers to be able to run in reverse more efficiently, right?
The T means “tank”, although it could mean “tenderless”. [(-D] Seriously, it stands for “tank engine”, and as Mark has stated, the water reservoir comprises either a saddle tank or side tanks. The saddle tank is draped in a crescent over the boiler which, after its contents gets warmed up, is great for feeding into the boiler.
The Kamloops Heritage Railway, about which I posted photos two years ago, uses an ex-CN 2-8-0 for an excursion from just east of Kamloops to Armstrong about 70 miles away. There is no way to turn the engine at Armstrong, so it is merely sent to the other end of the consist once a local diesel switcher swaps the caboose to what was the head end on the outbound trip. The Consolidation trundles along all the way back to Kamloops in reverse at the same speed, over the same track.
Growing up near the C&NW northwest commuter race track in Chicago, it seemed like half the steam locos were going backwards pushing/pulling commuter trains to/from downtown. To be honest, it seemed “wrong” when they were going backwards. In any case it is obvious that the prototypes did in fact run locos backwards as necessary.
In my model world, I have always felt strongly that locos should only go forward - with the exception of switchers and the like of course. I always provided for reverse loops on my layouts, for I do like to see trains going in opposite directions and don’t want to use to ol 0-5-0 switcher to turn them.
My last layout (demo’d last month) had two large reverse loops - one on the upper level and one on the lower level (staging/storage). Quite honestly, they were both a pain in the backside - although the upper one looked pretty nice and “did the job”. The layout was DC, and more often than not I would get the polarity switch wrong and cause a stall on a heretofore smooth run. And, the loop took up a lot of room that negated the “land use” for industries or whatever.
Soooo, the new one (now in the first stages of construction) has no reverse loops. I am wiring for DCC and realize the polarity issue is a mute point with the “reversers”, but the fact is the loops still take up too much room that could be better used.
Looks like my 6 steamers will either be going backwards or turned by hand afterall!
Class Ones like Reading and CNJ had steam engines in commuter service that were not turned, they did move to the front of the train.
The CNJ had one unusual branch line that had no run arround track at its end. A locomotive headlight was mounted to the caboose. When the train was ready to return the locomotive pushed the train, probably not very long. This was in the diesel era and I am sure they did it during the steam days as well.
I have a slightly different reason for asking the same question.
Is there a reason for turning model locos on a layout which is essencially a circle/oval where the trains running clockwise are only making right turns and the ones running anticlockwise are only making left turns? ie. Is flange wear a problems with models? I know it would take a long time to wear out model flanges, but is it likely to be a problem?
I can’t say for sure, but I believe it must be so. It may not be quite the problem that we are worrying about, but the physics, especially if you are getting your engines around fairly tight turns regularly, suggests that it will eventually cause the flanges to wear down. Not only that, but what about the effects of continual sideplay and deflection on the rods on either side? Will the uneven wear on one face at the pivoting point, the cranks, mean an earlier worn through rod? It therefore seems to me that the longest you could get a drivetrain to last would be by frequently and evenly running each engine around curves in both directions.
I say this as my opinion, and obviously can not support it with facts…
I believe you would have to run a given train “hundreds or thousands” of times around a loop before you would see wear that would make a difference. Of course if you had super tight turns and ultra heavy locos it would take much fewer revolutions to do so.
I also believe the track would show wear before the loco would. I recall a few times reading of long term layouts where the track did wear down - usually on curves - and had to be replaced. But, I never heard of a loco’s wheels wearing out (which is not to say it didn’t happen).
But remember, a given section of track is subject to wear caused by every loco/car that runs over it, whereas a loco is only subject to wear for the time it is running.
For what its worth - and in closure - I wouldn’t lose sleep over getting loco/track wear.
“A rod locomotive which had frequent, long-distance backwards runs would have a headlight facing rearward and a tender, if any, that permitted good rearward visibility.”
The same goes for helpers in many cases…switchers too.
steam locomotive drive wheels had tires that were a shrink fit onto the wheel centers. these could be replaced when worn past the acceptable limits or when they developed flat spots. rail on the other hand was constantly subject to wear on the gauge side of the outer rail on curves. sometimes it got so bad the wheel flanges were hitting the angle bars on jointed track. when this rail reached the limit of wear permitted, (i think it was about 2’) it was replaced and often then used for tangent track in yards or on secondary tracks. some roads used rail lubricators on their sharpest curves. when the powder river basin coal business really took off some years back, the Burlington was having a problem with rail on curves wearing out faster than they could replace it. in my 45 years of HO modeling, i have never worn out any rail or wheels but i see where that could be a problem on a large club or display layout. i think the original O scale layout at the museum in chicago had that problem near the end.
