Options for handrails on Athearn BB C44-9W ??
Are there any aftermarket handrail options for an Athearn bluebox c44-9w? I can’t stand those metal handrails.
Thanks in advance,
I would try Smokey Valley. I have used them for other BB models. They are as good as on a brass engine if you take care with the installation. If the rails are not one piece, bend your own from brass and solder at the stanchion.
http://www.smokeyvalley.com/Catalog.txt
Yes you can order the plastic handrail set for the RTR C44-9W since the RTR C44-9W is the BB locomotive.They are back ordered at Horizon so you may need to look around for them.
http://www.horizonhobby.com/Products/Default.aspx?ProdID=ATH49280
http://search.horizontrains.com/index.jsp?D=c44-9w&sid=116D478714EA&Ne=5000&Ntt=c44-9w&N=5574&vno=72
Thanks guys …
You might buy about ten of the plastic/rubber handrail sets as they will break as fas as you can install them.
Yeah,I keep a stock of Athearn and Atlas handrails because both break if you sneeze on 'em!
No,I break mine during routine maintenance.
I have a love/ hate relationship with these spaghetti thin handrails.
[#ditto] They look good, but are flimsy. Certaint types of glue will hold them though, so I use some of my broken ones or parts made from the same material to make stuff I need. (like an real RR)
