Once upon a time I could get stick on lettering but now, with computers, no need for them so no one stocks them. All I can get is stickers with little fairies on them, hardly realistic.
Has anyone printed them off a computer and treated them so they last outside. I dont want to cover them with plastic etc. Has anyone used something like nail varnish, and does it work ???.
Surely someone makes their own signs on a computer, sticks it on their buildings designed to stay outside, and what / how do you protect the printing it so it does not fade or wash away…???. I would be grateful if you could tell me what you did that didnt work as I dont want to put signs on my buildings only to find in a month or so there blank.
GR did an article (Dec. 2000) on one reader’s technique using the computer. He made a sign and printed it mirror reverse on transfer paper (the stuff you typically iron-on t-shirts), then ironed it onto a piece of wood. Spray on some Dullcote and it’s good to go. It makes some neat signs.
I made some station nameboards for my Pola G-scale station. The station name was produced on the computer using MS Powerpoint (because I wanted a border around the name, this was preferable to MS Word). I then printed onto nornal inkjet paper, stuck onto the plastic nameboard from the kit and then covered in transparent self-adhesive plastic (the sort that is used for covering books). Being station nameboards they are slightly shielded by the building and so have not so far suffered any effects from the weather.
Both the date on the bridge and the number on the tender are from those vinyl sets they sell in stationery stores. They hold up very well outdoors. I have them in both black and white, and inch and half-inch sizes.
There are several tricks to using them. First, use blue painter’s masking tape to make sure you put them on in a straight line.
Second, follow the instructions and mix a drop of detergent into some water and apply a very small amount to the surface where the letters are to be placed. When you get them where you want them, wick away excess water with the edge of a paper towel. Then you can remove the blue tape too.
In Tony’s defence and you all havent considerd it properly but he lives in New Zealand and this is a very small economy. You have very little choice and alernatives even less than we have here in Australia. So what you people can get easily and cheaply, Tony may not be able to get at all and even then he will pay a bomb for it.
Matt, my Lehmann caboose was sprayed with dullcoat about six years ago and spends most of its time outdoors. I have not seen any crazing or other ill effects, except that it has continued to remain dull – which is good in this case.
Originally it did not have any windows so I glazed them with plastic. The dullcoat tended to frost the windows, which is also good because the interior has no details.
Thanks to all that submitted a reply, gives me some ideas.
Ian of iandor, how right you are. Simple little things like stick on lettering is simply not available or if it is it costs a fortune. Your probably a little better off than me, but not much I bet.
I did find some, but at $1.20 a letter, no way…I can buy it cheaper but has angels, fairies or dogs around the letters…
Got heaps of ideas from Phill in Adelaide, and it is interesting how us down under have to improvise, and yet in many cases it looks far more realistic than a shop brought one.
I often wonder what a lot would do if things were not so readily available to them…
