over under help
I am building a layout that is 5x11 in ho scale. it has a 24" radius oval that has 2 turnouts to go to a 22" radius over under figure 8 for the incline I am trying to keep it at a 2% grade. The issue that I am running into is that the last peice of the woodland sceenic incline is right at the crossover point under the top of the track and I am only able to go with a 3" rise which with the roadbed and locomotive I barely have enough room for the locomotive to pass under. Does anyone have any suggestions on a better way to get more clearance? if I go with a steeper incline then the locomotive will have trouble pulling cars up the incline correct?
Congratulations! Your new learning and discoveries are oh-soooo-typical for people putting together their first layout.
Yes, your locomotives ‘may’ struggle quite a bit to get up steep grades, but you can set up a grade on a board, set a certain steepness, and then run a trial. You’ll learn what your locomotive can pull at a given grade, and it will be as close to empirical evidence as one can get. From there, you decide what compromises you’ll have to make to get what you want, including redesigning the entire concept (yes, many have had to do that).
There’s a trick with a figure eight. Your climbing track, the one overhead, needn’t do all the clearance-making. Instead, have your lower track, the one that passes below the top track, descend a bit and then climb again on the other side of the overpass. Yuh gotta do what yuh gotta do if you want to keep your space and track configuration the way you’d like it to be.
When figuring out the height you’ll need for clearances, don’t forget to include the depth of the bridge/overpass below the ties and rails. It matters!!
There is a forumula proposed by John Allen that the effective grade increases on curves by 32/R or 32/22= 1.45% So your 2% grade is really 3.45%
Small locos will have a problem. Double heading helps and some feel that is not a bad way to go.
A good idea but if you are building on a flat surface, plywood or foam, and using WS foam risers, they only go up.
Hello All,
Welcome [#welcome]
A few words of general advice…
Building any pike you will need some specialty tools. My go-to source is Micro-Mark.
If you are building overhead trackage I also recommend getting a National Model Railroad Association (NMRA) track gage.
If you are an NMRA member they are only $5.00 +S/H through them. Micro-Mark offers one for $19.95 +S/H.
This gage will help you determine the minimum recommended overhead track clearance, according to NMRA standards and recommended practices.
Yes, you can…
But that depends on the makeup of your sub roadbed. If you are using a foam base then you can carve out the decline under the overpass.
If you are not using a foam base this can be more difficult, depending on the material.
What are you using to build your overpass?
Are you using a Woodland Scenics incline/decline set, a concrete or wooden trestle pier set or fabricating it on your own?
You did not mention if you are running primarily steam or diesel motive power.
If you use a 3% incline/decline consider adding another locomotive to help in pulling power up the slope; AKA “Doubble Heading”.
Another option would be to run fewer cars up the slope.
Hope this helps.
First off thanks so far for the advice given. I am running strictly Diesel GP9 and SD45 I also have an ac6000 that may run on the over under. For the layout I am running a 1 inch foam bed but then plywood underneath, so technically I do have 1" to play with in carving down to go under then trestle, but I would rather not if I can help it because I was thinking of throwing a stream in there. for building the incline yes I am using WS incline set and as mentioned before they really just go up not up and down. There was also the suggestion of running a shorter train but I really like the look of a 15 to 20 car train (I am hoping that I can pull that up the incline) As for consisting the loco I think it would look a little funny an SD40-2 and a GP9 in consist…yes I know I am being picky and making this difficult :frowning:
Got a similar problem. Fiqured out if I ditched the cork just at the overpass and ran a peice of metal under the flex track, I could pick up the needed clearance to maintain a 2% grade.
Understood, which is why I added that he might be better of reconsidering his entire approach to the track system. If he’d like to investigate what that means, or what alternatives he could explore, we could take him there.
A stream is unlikely to be found carved through flat land. They DO at times, but not very often. A stream is more likely to have carved out a depression which the trestle will cross.
Could you add another layer of foam? That will give you more relief space to carve.
You’ll get to run that longer train you’re hankering to see run on your layout if you do the work to make it a reality. Constructing a pleasing layout is not quick, and generally not easy. It takes forethought, and it takes flexibility when you encounter obstacles to your vision that reality and learning place before you.
