I need your help, I’m looking for a P2K 2-Window SD60M in Burlington Northern. Has anyone seen one anywhere online or at a hobby store? I can’t seem to find one anywhere. I already have the 3-window and should have bought the 2-window when I had the chance, but now that chance is gone.
If you check on ebay, there are some that show up. First check the sellers rating, if better than 99 percent I would be comfortable buying from the seller. If the seller does not specify 2 or 3 window version, look at the picture, if the windshield is a bit slanted it is a 2 window, if it is 90 degrees it is a 3 window. And if not sure just ask the seller. These usually go for 50 to 100 bucks on ebay.
Thanks for the help. I have checked ebay and will continue to. Oh, and thanks but I do know the difference between at 2 window and a 3 window. I already have a 3 window in BN and UP.
