P2K E6 close coupling conversion
As a few of you know, I purchased a Proto2000 E6 A/B w/dcc sound awhile
back. The only complant I had was the lack of close coupling… it just made
the loco look bad. So I ordered the Kadee #455 conversion kit. It took a
little time, patience, drilling and tapping, but I like the results. Well worth the
time. Dave
Before conversion (click for larger veiw)
After conversion:
And here’s what it took (although I only had to use one of the tap sizes)
What KD Coupler # and what’s your radius?
The kit comes with Kadee #33’s.
I have 30" radius mainline curves. Dave
With the close coupling, will it run on 22" radius? I just bought the E6A+B in Atlantic Coast Line purple myself (no DCC). I just don’t have the room to run larger than 22" on my layout.
One problem that I’m having though is that for some reason, my B unit couplers sit slightly higher than my A unit and my freight cars. What’s the easiest way to fix that? Is it possible to shim down the couplers on the B unit?
I’m not into shims but you can review the merits of KD overset shank that lowers the coupler head.
http://www.kadee.com/htmbord/page67.htm
I have an Athern PA1/PB1 and have the same problem, no close coupling. The couplers on this set is truck mounted. I did add working diaphargms, and kadee #27 short shank. Currently I run 22" radius track, and still there is about 1/8 between the diaphragms on the straight runs . Are there any Kadees out there that are a little shorter?
Thanks!
Thanks Dave for posting your photos of your E-6 A/B Kadee #455 coupler conversion. I’m pleased you had the patience and bravado to follow through with the conversion, good job!
When properly installed and you use the diaphragm plates this #455 conversion will allow the locos to negotiate 18" radius “S” curves.
To rrgrassi: This link to our web site http://www.kadee.com/conv/pdf/ath4.pdf will show you a couple of conversion ideas for your Athearn PA1/PB1. The #38 is for close coupling. But if you do not wi***o alter the mounting you might try the shorter #24 or #44 coupler in place of the #27.
Sam Clarke
Kadee Quality Products
SROC99
Thanks for the info! I’ll give it a shot! I love the strength of the Kadee. Does Kadee make a McHenry replacement for Rivarossi 3 axle and 4 axle passenger cars?
Thanks!
TO: rrgrassi,
We make our #505 and #508 for AHM, IHC, Rivarossi, and most Con-Cor passenger cars.
Use the #505 on 6 wheel trucks and the longer #508 on 4 wheel trucks.
We experimented with “snap in” couplers for this type of mount many years ago and found them far too inconsistent for our standards. You will have a bit of trimming and fitting for the #505 and #508s but you’ll find they are a solid mount and have a bit of adjustment for close coupling.
Sam Clarke
Sam,
Thank you, for providing quality products. I have tried other couplers (I won’t mention names)
and I honestly can say, IMO, that Kadee is the best on the market. Keep up the good work. Dave
I agree, for me is either Kadee or nothing. Sometimes they can be a pain to install, but they are well worth the effort, and after they are installed, you just do not have the uncoupling problems that are presented with other knuckle couplers. I do not know why manufactures insist on using the other couplers as OEM.
Thanks to Sam and all the Kadee people that keep 'em hooked up!
