Hi all,
I just received a new double-action Paashe airbrush in the mail yesterday, and when attempting to connect it to my air compressor, I discovered that the large connector on the compressor end of the airbrush is slightly too large to screw onto the compressor’s output valve, and the hose from my old airbrush won’t fit onto the Paasche. I’ve also noticed that the Paashe seems to have a valve where the air hose fits. And as such, I have two questions:
Am I able to get an adapter that will allow me to screw the Paashe air cable onto my compressor?
Or failing that, would a replacement hose with the correct connector at both ends be compatible with the Paashe (given the valve-like thing in the air input)?
Thanks in advance,
tbdanny
