Hello!
Im currently restoring a Santa Fe 4-8-4 northern. Front seeing pictures online, it seems that half of the engines have a gray/white/silver ish color to the smokebox front, and the other half are black. I heard that the smokeboxes were painted black during the wartime…?
Which color is accurate?
What brand of paint would be the most accurate to the prototype color?
Generally, the smokebox and firebox of a steam engine got too hot to paint - the paint would just peel off due to the heat. Instead, these parts were coated with a mixture of graphite and oil. Graphite is what pencils use, so it would be roughly that color.
ATSF extended the jacket construction on some locomotives especially 4-8-4s. Than the smokebox would be painted black.
Graphite is not one specified color. As it was mixed in the shops. There were many shades from silvery to almost black.
Southern Pacific had smokebox and smokebox front painted graphite until 1946. In 1946 Aluminum paint was heat resistant enough that SP used it on the smokebox from from then on.
I have seen ATSF models with silver smokebox fronts but I’m not sure if ATSF used Aluminum paint.
Regards, Volker
I have always understood that Santa Fe called the color Tarpon Gray, but have never heard what the graphite coponent was, or if there is a good color match available.
I believe the smokebox isn’t insulated, normally. It’s hot surface would drive off volatiles over time and you’d be left with a roughly waterproof crust, sort of like a seasoned cast iron skillet. This means they would get dark over time and be less easily distinguished from the rest of the grimy cladding around the boiler.
